Question about Ricoh Caplio R7 Digital Camera
Problem with zoomi cannot use the zoom to is full power,
In Chile just bought a camera Lumix DMC FZ70, zooming only works in automatic mode AI in the other modes only works zoom 1 to 3x, please indicate what should I do
First thing Ariel is to read the manual. Specs say it has something called 'Intelligent Zoom', so it might be by design.
Panasonic Lumix DMC-FZ70 / DMC-FZ72 Key Features:
  • 16.1-Megapixel 1/2.3" High Sensitivity MOS sensor
  • LEICA DC VARIO DC 60x (20-1,200mm) Ultra Wide-angle Zoom Lens
  • 120x Intelligent Zoom
  • POWER O.I.S. (Optical Image Stabilizer) with Active Mode
  • LSI Venus Engine Image Processor
  • 3.0-inch 460k-dot Intelligent LCD Display
  • 0.2-inch 202K-dot EVF (Electronic Viewfinder)
  • 1,920 x 1,080 60i Full HD Video Recording with AVCHD (MPEG-4 / H.264) Format or 30p in MP4 with the Dolby Digital
  • Built-In Wind Shield Zoom Microphone
  • Up to 9 fps continuous shooting
  • ISO up to 6400
  • RAW file recording
  • P/A/S/M Full Manual Control
  • iA (Intelligent Auto) / iA Plus Mode
  • Creative Panorama
  • Creative Control
  • Creative Retouch
  • Creative Video Mode
  • HDR (High Dynamic Range) mode
  • 3D Photo mode
  • Optional DMW-LT55 Tele Conversion Lens extends the zoom ratio to 1.7x to pull the subject far off even closer with minimum deterioration of image quality.
  • Optional DMW-LC55 Close-up Lens
    http://panasonic.ca/viewing/ALL/DMC-FZ70P/OI/vqt5b59-eng/vqt5b59-eng.pdf
Jul 04, 2016 | Panasonic Lumix DMC-FZ70 Digital Camera
Picture too wide on tv
Sounds like you have the "Wide" mode set to Zoom or wide zoom. Also if you are on Comcast cable the cable box has a setting of Zoom and full. Set your TV's zoom setting to "Full" and the cable box to Full. I don't have an LG so you'll have to find these settings yourself..
Feb 25, 2015 | LG 47LM6700 47" Class FuHD 1080p LED LCD...
It blinks with "be" and turns off
It may be "but" that you're seeing, which indicates the batteries are low. Use the AC adapter made just for this model only, and the guitar needs to be plugged in to turn the unit on. A full manual for this Zoom model can be found here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Dec 01, 2013 | Zoom Samson Technology Zoom G1XN Multi...
No power or display when I turn on the gadget, even using battery, it will display sometimes but a blink oh "be" letter appears on the screen
Can zoom in or out when in full page mode anymore, just started yesterday aug 10/11
there is a pretty obvious bug when using 'Marquee Zoom' (Alt+5) in the full screen mode (F11). When you press 'Ctrl' to toggle 'Zoom In' and 'Zoom Out' (changing the little magnifying glass cursor from + to - and back again), it sticks with 'Zoom Out' and refuses to toggle back to 'Zoom In'. And then the only way to recover 'Zoom In' is to exit full screen mode, whereupon 'Ctrl' regains its toggling power and everything is back to normal
Aug 11, 2011 | Computers & Internet
Hi, I have a DMC-FX30. When i turn the zoom
mera Digital Camera Hi, I have a DMC-FX30. When i turn the zoom Answer Failed: retry Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be... (More) (More) Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be stopped - only when i switch the camera off. Can you help?
Feb 11, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Auto zooming on power up, intermittent problem
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Sep 28, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Lock up
Zoom failure suggests zoom motor stalled - no repair Un able to take photos- main circuit failure. Checxk all the ovoise things Battery state- is it goog and delivering full power. Have you set it to the Photo mode or is it stuck in some other function. Get hold the the manual and do a thorough check of all functions. There is usually a FULL manual in PDF format on the supplied CD.
Sep 09, 2007 | Nikon Coolpix 950 Digital Camera
Ricoh Caplio R7 Digital Camera Logo
18 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
