Question about Dell 926 All-In-One InkJet Printer
I tried to use the fax on my Dell Photo 926 all-in-one printer, and when I sent the fax to another fax machine, it was able to reach the other fax machine, but the fax faild (nothing was exchanged), and it eventually hung up. Then, my friend at the other fax machine tried to fax me, and the same thing happened. He hasn't used his fax for some time, so we're not sure where the problem. Any one out there have a simple solution for a "remedial" student ?
  • 2712 Answers
SOURCE: Dell Photo 926 printer scanning problems
Go HERE and select your OS and download the latest version of the driver. Then uninstall the older version on your PC, reboot, and install this version. Dont plug in the printer to your PC until instructed to do so in the installer.
Hope that helps! Should you have any further questions,please feel free to post them here.
P.S. – I would greatly appreciate a FixYa!rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Posted on Oct 30, 2008
  • 69 Answers
SOURCE: Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
Posted on Nov 07, 2008
  • 495 Answers
SOURCE: Dell Photo 926 Power cable
You can get it from site below:
Posted on Jan 08, 2009
  • 55 Answers
SOURCE: Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
XP Printer Application
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Posted on Mar 02, 2009
  • 4041 Answers
SOURCE: paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
What mode does 926 Printer must be in to print?
For printing from the computer, I beleive it is 'copy' mode.
Mar 30, 2014 | Dell 926 All-In-One InkJet Printer
I can't get dell photo cartridge for 926 all-in-one inkjet printer to lock in its holder.
try pushing it? try to remember how you took out the old cartridge then reverse it dell printer
Nov 27, 2011 | Dell 926 All-In-One InkJet Printer
How to scan on the dell photo 926
Download the latest printer software/driver for your operating system at the site below.
click start, click printers and faxes, click scanners and cameras, double click on scanner image device (scanner and camera wizard pops up) follow instructions from there.
Jul 28, 2010 | Dell 924 All-in-One InkJet Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Photo 926 fax no dial tone
ALL fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
Jun 30, 2009 | Brother IntelliFax-2820 Laser Fax
Power off the printer and disconnect the USB (Parallel ?) cable from the printer to the PC. Reconnect the cable. Restart your PC.
If that doesn't work ... go to Start - Printers and Faxes and delete the Dell Photo 926 icon. Then, power off the printer and disconnect the cable from the PC. Power on the PC and log in. Reconnect the cable and see if the printer is found. If so, install the Photo 926 printer driver. If the printer is not found, you have a printer cable or printer hardware problem. Good luck.
Jun 11, 2009 | Dell 926 All-In-One InkJet Printer
926 printer
my 964 printer have the display totaly black no copier and print ok
Oct 20, 2008 | Dell Photo 964 All-In-One InkJet Printer
when it's asking for fax modem means that the printer is trying to connect somehow to internet (to connect to the homepage of dell probably) ..easy to get rid off this ..but first is the printer correctly installed (is it shown in your printer's folder (start>parameters>printers) ?
Aug 15, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
128 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
