Question about Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200 not charging
My Garmin will barely get past the Loading Maps screen and just turns off.
I also have a Nuvi 200 that didn't charge. The problem is the charging port disconnected from the circuit board. You can disassemble the unit and reconnect the charging port but it takes a small torques wrench and a small screw driver. You will also need a soldering iron preferably with a fine tip and a very steady hand. Good luck.
Posted on Dec 07, 2009
1300 nuvi screen comes up loading maps and stops
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
Upon turning my Garmin Nuvi 1300 on it sticks on the screen that says "GARMIN".......Loading Maps. It never goes past this screen. I have had this unit since the end of December. It is fully charged and I...
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Apr 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
GPS doesn't boot up
I can help you fix your Garmin Nuvi 200W.
Getting stuck at the Loading Maps page or rebooting before finishing is a sign that the system software or firmware of your Nuvi has become corrupt.
There are three steps to take to get your Nuvi running like new:
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 28, 2010 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 205w will not boot past the loading
Yes, it's a software bug and the only way to fix it is to RMA it to Garmin and they will send you a new one. Waitin on my replacement now.
Dec 22, 2009 | Garmin nuvi 205W GPS Receiver
My sat nav 1300 won't get past 'loading maps'
IT WILL STILL BE UNDER WARRANTY BUT TRY A SOFTWARE DOWN LOAD FROM WWW.GARMIN.COM THEN TAKE IT BACK TO THE SELLER
Dec 18, 2009 | Garmin nuvi 1300 Car GPS Receiver
When garmin 200 is turned on it says it is loading maps and after you hit the agree button it says"no detailed maps found that support routing. the nuvi cannont be used without them".
Not being able to start up is a sign that the system software or firmware of your Nuvi has become corrupt.
I hope that helps.
___________________
Sep 05, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 260W shuts off before it fully loads maps
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
Garmin is stuck at loading maps
I had a 200 W Nuvi with the same problem. Luckily it happened with the first 3 months, so i could return it to Garmin under warranty for a free replacement
Jun 17, 2008 | Garmin nuvi 200W GPS Receiver
New GARMIN 660 Won't get past the Intro screen
Problem solved: I got through to Tech Support. They suggested a 'hard reset', which solved the problem: Put you finger on the lower right screen while you power up and it will do a hard reset---and it will get past the "loading maps" screen, where it had been stuck.
Dec 25, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
511 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
