Question about Sony DSC-T7 Digital Camera
Memory card problem
When there is a brand new 4gb memory card in when switched on the camera says no memory card
  • 571 Answers
I'm not 100% sure, but since this is a bit older model, there is a possibility that the camera can handle max. 2GB card. Try with a smaller card first.
Posted on Oct 03, 2009
Camera will not format sd card nor does it show a card in the camera
Something tells me that you're trying to use a brand new 4GB SDHC card. If so, your camera was designed before SDHC format came out. You'll need to use standard SD cards, those 2gb or less. Search on Amazon for "SD card 2GB". They run about 6 to 7 dollars total with shipping.
For others with similar problems, There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 25, 2011 | Samsung NV3 Digital Camera
My memmory card says it is write protected what to do?
By the way, if you're using a brand new SDHC card, the L10 is indeed an older camera and can only utilize 2GB or less standard SD cards.
May 29, 2011 | Nikon COOLPIX L10 Digital Camera
My Kodak EasyShare V530, won't accept a memory card, you insert a memory card, and it doesn't even acknowledge that there is a memory card inserted.
I bet the memory card that you're inserting is a brand new 4GB SDHC card (your camera can only use 2GB or less standard SD cards). There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Apr 10, 2011 | Kodak EasyShare V530 Digital Camera
Hello I currently have a 2 GB memory card in my canon SD 1000, camera i want to upgrade to 4GB memory card, what is the best brand or type? Will 4GB SDHC memory card work with my canon camera? ...
The Canon SD1000 will work with SDHC cards, up to 32GB in size. Stick with any of the major brands and you won't have problems.
The HP 7350 will NOT work with SDHC cards, limited to SD cards 2GB and smaller.
Mar 26, 2011 | HP PhotoSmart 7350 InkJet Printer
I can't get the camera to accept a sd memory card. It keeps saying check sd card, but it's brand new. Why is this?
Are you using a 4GB or higher "SDHC" card with your camera? Note that the S800 can only use "standard" SD cards (those 2GB or less). Fortunately, these are very inexpensive these days, recommend checking on Amazon.
For those that encounter this problem, there are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jan 05, 2011 | Samsung Digimax S800 Digital Camera
I bought a new SD card for my powershot SD600. I have tried two different cards and they both say they can be formatted. What is the problem?
Bet it's a brand new SDHC card.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Nov 15, 2010 | Canon PowerShot SD600 Digital Camera
When I inserted the new memory card (SanDisk Ultra II, 4GB) into my Canon PowerShot A620, it tells me "Memory Card Error". This is a brand new card. What do I do? It had been working just fine with a...
Some cameras cannot handle over 2GB memory cards. If it works fine with 2GB card - stick to that. If some other A620 you know operates with 4GB card, take yours to repairs.
Oct 24, 2009 | Canon PowerShot A620 Digital Camera
We put a new 4gb flash card in and on the display it says no memory card,we then put the old memory card in and that says memory full but says theres no photos on the memory??pls help
Your camera probbaly does not use SDHC... just SD...
Find an SD memory card, it will work. The 4GB card says "SDHC", not "SD".
Please post the brand and model or whatever you can ... which camera?
Sep 19, 2009 | Cameras
4gb not compatable?
camera wont accept a 4gb card most only take 2 gb sd cards .
Jun 03, 2009 | Nikon Coolpix 5000 Digital Camera
4gb not compatable?
It could be as simple as a bad card. Take it back or try it on another camera to verify.
Mar 10, 2009 | Nikon Coolpix 5000 Digital Camera
Sony DSC-T7 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
