Question about Pure Digital Flip Video Camcorder
My flip video has a broken lens. Where can I get this repaired?
  • hippiechickl Feb 23, 2010
    I haven't fixed it and would be most thankful if you could tell me how to fix it!
    Thanks so much!
    Patrice
    Yes my flip is still broken. If you could show me how to fix it I would be most thankful!
    Thanks,
    Patrice
If you've never received an answer to this, I have a Flip UltraHD that had the same problem. I took pictures all along the way of fixing it. Let me know if you'd like to see how to fix it! Not hard at all if you're GENTLE!
Shame on Flip for not making this simpler!
Posted on Jan 19, 2010
  • 1 more comment
  • JPTinKS Feb 26, 2010
    Sure... sorry took so long to get back. Had to upload the images from my camera. Basically, here's the steps:
    1. With a VERY slender blade, slide it underneath the little ring that covers the glass lens. Be VERY VERY careful not to bend it because it's very fragile. If you bend it, it's going to look like **** when you stick it back on at the end. No, I haven't shown you the end result. Just go to hobby lobby or somewhere to get a clear plastic piece and cut it to the proper size.
    Anyway... here goes. Step by step...
    Here's what it looks like before doing anything to it. Look at it closely and you'll see the place where the cover joins the camera. There's a bit of sticky stuff that holds it on, so just be prepared to pull GENTLY to get it off without bending it.
    Now... take a blade that you can work up underneath the cover...
    And keep working the blace around the outside of it. Do not just pull the cover off after you have the start of it otherwise you'll bend the cover.
    After you've worked the blade completely around the cover, you can gently pull the cover off. Again, be very careful to not bend it!
    Here, you can see the sticky stuff that's been holding the cover on. The glass lens will stay in its cradle still. That's okay. Just keep pulling it off gently.
    This is what it looks like after you get the cover off. Note that the glass lens is still in the camera. Gently peel the stick stuff off of the cover. You can see in this picture below that I've already taken the sticky stuff off.
    Now... we'll start picking the glass shards out of the camera unit. Be very careful not to scratch the lining that the glass sits in. It's okay to let the glass fall down into the unit. You'll just have to either get canned air to blow it out, or very gently shake it out. Your choice.
    Keep picking the pieces out of the camera, and make sure you clean all of it off the edges. In the following picture, you can see that I've cleaned out the glass from around the edge, and am just finishing up getting it all out.
    Finally, here's the finished result with the cover off, the glass taken out, and the rim of the camera that I've cleaned out all the glass shards. You're now ready to get whatever you have access to (glass or plastic) to put back in the unit. Take note here of how thick the glass is and take a small piece of it with you so you can get the proper thickness at the store (or jeweler as another poster has said). You'll just have to cut it to size, stick it back in and either user plastic cement or rubber cement to stick the cover back on.
    There you have it! Wish you the best!
    Patrick
    Sorry... forgot to put the last image in here. Here's the final picture of how it looks after getting all of it taken apart.
  • JPTinKS Jul 05, 2010
    Glad it worked!
    Patrick
EBay has them for $15 bucks. Easy install.
http://tiny.cc/ms38j
Posted on Jun 29, 2010
  • 5 Answers
I purchased a replacement Flip Video Lens from eBay. Cost $15 bucks and free shipping. Easy to install and saved me from buying a new Flip.
Posted on Jul 04, 2010
  • 2 more comments
  • jallynfisher Jul 24, 2010
    Amazon has them for $15 and so does eBay. It is the repair kit. Go with this one. The glass is specifically made for the Flip cameras. It is not just mineral watch glass that others are selling for $10 bucks.
  • ulimed Nov 04, 2010
    Hello, can you post the link to buy it, thank you, I tried to search but I could not.
  • jallynfisher Nov 05, 2010
    Search flip video lens on eBay and it is the one that sells for $15.99.
  • martin thomas Sep 07, 2011
    Esslinger & Co. [esslinger.com] sells a Flip Video Camera Lens Replacement Kit item# 110.161, which? comes with the correct size crystal for replacing the lens and the tools needed to do the work, Easy Breezy!
I really want to thank JPTinKS. Because of your post I was able to fix my flip cam after the lens broke all by myself. I took it to 5 jewelry stores in my area and even a watch repair shop to replace the lens cover and NO ONE would even touch it. They all said it couldn't be done and didn't know how it could be (after I told them that I read online that it could be). One even said that I could take it apart myself, then bring it to them and they could look at it and see if they could fix it - for $40!!!
So, I used this post and took it apart by myself using an Exacto knife. It was so simple. It literally took me 2 minutes (and JPTinKS is right, the outer rim is SUPER delicate so be careful not to bend it, like he said!). I then found a watch repair website ( http://www.esslinger.com/roundmineralglasscrystalx1mmthick.aspx ) and ordered the crystal to replace it myself. The measurements are 1mm thick and about 20mm diameter. The lens itself cost .88 cents! Only problem with this site is that you need to order $10 worth of stuff for the minimum order but it ships fast and is exactly what you need to fix your lens cover. To meet the $10 I ordered extra lenses (though I think this will probably last longer being they are a high quality crystal), watch glue (to glue it back into place) and a pair of watch tweezers (to meet the $10 PLUS it seemed like a good idea so I didn't get fingerprints on the crystal).
If you attempt this, good luck! It's really simple. The hardest part is taking the outer cover off of the broken camera without bending it - other than that though, it is extremely easy!
PS: Just a side note: The new lens is slightly different than the original being that it doesn't have the black rim on the crystal (since it is watch crystal) but you don't need that - it's just paint anyway for aesthetic purposes!
Posted on Apr 22, 2010
You want Mineral Glass like Esslingers site or their ebay The Mineral Glass is Hardened and tempered so it doesnt turn color, scratch or break easily, Plastic scratches very easily and is not what you want for a lens or dust cover! Plus they are the only ones I have seen with a tool kit and epoxy and an extra crystal in case you screw up or have to do another camera...
Flip broken lens repair kit
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=180714135044&ssPageName=STRK:MESE:IT
Flip Broken Lens Repair kit WITH TOOLS
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=180714135661&ssPageName=STRK:MESE:IT
Or you can get it from there website:
http://www.esslinger.com/flipcameralensreplacementkit-1.aspx
I'm just posting this because when I needed my camera fixed I contact them and some other guy on ebay and they were very helpful and fast shipping. Shop around though there may be new sellers on ebay or amazon to I dont know about,
Now I am about to purchase a Flip Slide for ym girlfriend anyone know if those use the same size dustcover? Thanks guys!
Posted on Feb 07, 2012
Jptinks,
I have same problem. Would you please show me the pictures of fixing the lens protector?? Thanks.
Posted on Feb 20, 2010
Same thing happened to me in the Middle East, Muscat Oman. I read all your posts on this site and others. I took it to a tiny Souk (market) watch repair guy and he fixed it perfectly overnight for 6 Omani Riyals =$US 15 so if a little old Indian guy can do it here overnight someone near you in the US should be able to.
Posted on Feb 15, 2010
  • jallynfisher Sep 07, 2011
    The replacement lens is available on eBay as a kit for $15.99. Works great and easy to install with the directions provided.
When my sons try to play a game, the screen stays on the main menu. Its like the system is not recognizing that a disc has been entered. This has happened before, we did factory reset as well as upd
The fact of the matter is, your system is not reading the game disks. The option to use a cleaner is always the best way to trouble shoot. After you use one, try a different kind of disk, like a DVD and see if it plays. If not, then your BlueRay drive is bad, and I would suggest sending it in for repairs.
Dec 20, 2014 | Sony Playstation 3 (PS3) Console
I have the canon powershot a2200 and the screen is just black as well as my pictures
okay 1 of 2 things is wrong i think A) the lens or that area is broken some where B) the screen is broken what you need to do is send it to canon so they can tell you what the problem is
if the screens broken buy one off the internet open the camera using a eyeglass screw driver or you will strip the screws look how the screen is connector flip the switch and take out and replace you screen the video that i have linked isn't your camera but the assembly and disassembly should be the same and so the screen changing i cant help you if its problem A) my only advice buy a new camera if cost effective or get it repaired
Apr 05, 2011 | Canon A2200 Digital Camera
When i turn my flip video on, it will display the flip video screen for a half second, then turn off. How do i fix it
did you drop it because if you dropped it something inside the main board of it may have broken. this happened to me. if that did not happen i would say call cisco which is flip's maker.
Mar 01, 2011 | Flip Video Flip Ultra Camcorder 2nd...
My lens is cracked on my flip cam, how do i fix it?
They aren't too hard to open up and take apart. There's a glass piece the covers the actual lens and I'm guessing that is what broke. Once the flip is in pieces you can remove the glass piece and it will operate fine without it. If you want to replace it, you can either get a broken flip and use it for parts, but there's a pretty sticky, tough ring of tape holding that glass piece in place. You could also try a very clear piece of plexiglass and cut it to size. Haven't tried that one myself, but it may work.
Apr 15, 2010 | Pure Digital Flip Video Ultra Camcorder
My son dropped our flip camcorder and the lens is cracked
[eBay] has replacement lens for the Flip Video. $15.99 free shipping. Also comes with protective lens covers.
Jan 03, 2010 | Pure Digital Flip Video Ultra Camcorder
How much would it cost to fix my flip video cause
how much would it cost to fix my flip video cause it has a broken screen but still works
Dec 23, 2009 | Pure Digital Flip Video Flash Media...
Broken lens
Had a broken lens as well. As you're probably aware it's not really a lens but a protector like a watch crystal. So I went to a jeweler who said, "Oh I don't know, it's not a watch. Bla bla bla." I said I'm not going to hold you accountable. He said fine. He fixed it easily. $20.
Oct 01, 2009 | Pure Digital Flip Video Camcorder
Is there a phone number for Flip Technical Support? I've had my Flip Mino HD less than a week, and am getting nowhere with e-mailing Tech Support over a defective product. The Credit Card compnay says I...
The tech support number is 415.445.7626 and then option 2. I just spoke with Kevin, the floor supervisor and he was less than helpful. My brand new minoHD simply won't work--not very impressed with this camera, and I hope Cisco hasn't made a huge mistake...
Feb 10, 2009 | Pure Digital Flip Video Ultra Camcorder
Nikkor 105mm Ai-S micro lens aperture seems stuck
It does sound like your lens diaphragm/aperture ring coupling mechanism is in need of repair.
May 03, 2008 | Cameras
Pure Digital Flip Video Camcorder Logo
8,110 people viewed this question
Top Pure Digital Video Cameras Experts
Rommel Balcita
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
