Question about Apple iPod nano
When my headphones are in the music wont come on but when its in my ihome the music works
  • 496 Answers
Theres a good posibility that your headphone jack is messed up and needs replacing the ipod uses the charging port when connected to the ihome and not the headphone jack
Posted on Sep 25, 2009
Can Bluetooth still work if the ihome is not plug into an outlet? Like can you take it places and can it be portable
Bluetooth is a smart replacement for connection cables. Thought for very low power information (music) exchange. It will connect devices over a range of maximal 10 yards. (about 10 meters) If you were using a bluetooth headphone to listen music on your iPod, as soon as you plug in a wired headphone, the bluetooth connection will be disconnected, because your device only can serve one master.
I hope I could shine any light on your blue tooth.
Jul 08, 2014 | Audio Players & Recorders
The battieries overheat
Are you using rechargeable batteries? Are they overheating when plugged in?
Mar 26, 2013 | iHome Sdi Ihome2go - Ih32b Ipod Portable...
For some reason my ipod touch won't play when I plug it into my stereo. It is playing out of the ipod itself. How do I turn this off.
Hello.
This is a very common problem, you may have to get a different jack that works with the headset jack thats on the iPod. iPhones and iPods have a weird style jack on the top that wont allow most headphone or 3.0mm to 3.0mm jacks to go fully inside the jack causing it so there is not connection with the jack itself in the iPod. You can check this by turning the volume up and down using the rocker buttons on the side while you are at the home screen with no music playing and see if it says speaker or headphones when your turn the volume up and down. Speaker means there is no jack connection, headphone means that there should be music playing through the stereo. Thats using the jack.
If your talking about an iHome or other direct plug in stereo specifically for the iPods and iPhones, make sure that the dock is the correct dock for the iPod, and make sure that it is pressed fully down onto the dock. If all that is correct there should be no problem. If the problem still is happening, it may be your stereo. =/ Goodluck! Hope this helps!
Dec 07, 2009 | Apple iPod touch
I want to play a Zen V on an ihome (portable speakers)
there is a double jack wire that should have come with your ihome plug one end ito your zen head phone hole and the other end in the back of your i home thats how mine works idk about yours but it should work the same for all ihomes
Nov 01, 2009 | Creative Labs Zen V MP3 Player
My iTouch is fully charged but wont turn on
hold don the top and bottom button and the sam time and keep it held down till the apple logo shows
Oct 15, 2009 | Apple iPod touch
Ihome won't play ipod, even after resetting ipod I have de same problem. I got an itouch 2nd generation and docked it on a speaker that supports it. It worked fine for two or three hours, but suddenly it...
Welcome to the wonderful world of the iHome frying the Ipod.
Your iHome, has most likely fried the mainboard on your ipod.
to check plug a usb into the ipod and connect to the computer.
if it comes up disconnect the usb and try a headphones in the jack.
if it doesn;t play sound its fried and you will need a new mainboard.
if it does play through the headphone jack, your lucky and keep it off the dock.
I have fixed at least 30 ipods taken out by ihome docks and other docks.
they are terrible for the ipod. Even Apple sells the docks on their website
that shows how much they care about the product.
If this helps leave a vote on fixya
May 11, 2009 | Apple iPod touch
Ihome ih9 wont work with 3rd generation ipod nano
Look at the Box and the Manual! 3rd Generation is not supported by iH9! Clearly marked on the Manual.
Jan 03, 2009 | Dual Electronics ihome iH9BR iH9 Alarm...
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
Wont play music
Although the connections are very similar, the iHome is probably only for and iPod, and not compatible with Philips MP3 players.
The only dock I know of that is compatible is the AJ300D
Jan 01, 2008 | Philips HDD1630 MP3 Player
Problems with Headphone and USB plugs
I share the same problem - I'm worried it's due to routine wear-and-tear on the jacks, so the connections are no longer solid. I hate to think I need to get it serviced for this. Usually buying a new cable has worked, but that gets expensive too... Anyone have a fix??
May 06, 2007 | Apple iPod nano
Apple iPod nano Logo
95 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
