Question about Enlight Interactive Scrapland for Windows
My pc locks up when i clip on Scrapland icon - Enlight Interactive Scrapland for Windows
I want to reset my Ematic Genesis Prime XL - EGS102. How do I do this?
  • 1 Locate the reset button. On some Ematic models, it's on one of the sides of the device, a small hole.
  • 2 Place a small object, such as a paper clip, into the hole to press the reset button.
  • 3 Remove the paper clip. The tablet turns off and then on again.
  • Oct 18, 2014 | Tablets & eReaders
    How to upload music files from sansa clip to IMAC
    Plug the device to pc, it will appear icon "sansa clip..." or removable disk, double clip on that >> double on Music folder >> drag & drop songs from Music to pc.
    Good luck
    Apr 29, 2010 | SanDisk Sansa Clip MP3 Player
    Scrapland and XP blue screen error - any solution?
    it will be your memory(ram) problem .. check ur ram requirement of game...nd upgrade or replace the faulty ram
    Aug 24, 2009 | Enlight Interactive Scrapland for Windows
    Scrapland Problem
    i deleted videos...i played gamme without it...
    Aug 21, 2009 | Enlight Interactive Scrapland for Windows
    How do i delete saved data on scrapland PC
    navigate under the hardrive you installed it. locate the install folder and trace it back to saves, save, saved games etc. Erase all content in folder. If you are using Vista it may be located under games folder instead.
    Jun 03, 2009 | Enlight Interactive Scrapland for Windows
    Blackscreen in scrapland
    I got it to work by disabling ffdshow.
    In Vista go to start.
    In the search box type in ffdshow.
    Click ffdshow video decoder.
    ffdshow video decoder config will open.
    In the left pane click direct show control.
    On the right make sure the box next to "dont use ffdshow in:" is checked.
    add Scrap.exe;Scrapland.exe; to the text field
    click ok
    game should work after that
    Apr 17, 2009 | Enlight Interactive Scrapland for Windows
    Scrapland and vista, error starting game - solution?
    my friend you can go to launcher.exe and
    1 right click and properties .
    2 compatibility and then select mode windows XP/nt
    click on the other icons try it works.
    reply about the result.
    Mar 28, 2009 | Enlight Interactive Scrapland for Windows
    Sansa clip; Does not appear on icons
    unplug Sansa MP3 player from your PC, go to menu ->settings, scroll down to USB-Mode, change mode from MTP to MSC, re-connect, yout PC will connect, detect new usb devive, disk drive.... and your sansa icon will be displayed at computer folder.
    Good Luck
    Dec 25, 2007 | SanDisk Sansa Clip MP3 Player
    Enlight Interactive Scrapland for Windows Logo
    21 people viewed this question
    Top Enlight Interactive Video Game Consoles & Games Experts
    James Wishart
    Are you an Enlight Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
