Question about Garden
Having difficulty threading fuel lines into the gas tank on a craftsman gasoline powered blower Model# 358.797342
  • 62 Answers
TAPER ONE END OF FUEL LINE AND FEED IT INTO TANK, WITH LONG NEEDLE PLIERS GO INTO THE TANK THOUGH THE GAS CAP HOLE AND FEED THE LINE THAT WAY MAKE SURE USE HAVE SOME EXTRA FUEL LINE
Posted on Sep 24, 2009
How do you replace fuel lines on a craftsman 16" chainsaw model#358.352161?
remove the carb and then pull fuel lines from tank ,there should be a filter in tank attached to the fuel line you will put that on the new line then feed it through from in the tank out
Oct 30, 2014 | Craftsman Garden
My Craftsman lawn tractor will run for a while and then stop then sometimes after sitting for a while will run again. What should I check? I added fuel additive to gas just incase the fuel was bad.
Drain the fuel tank. Dispose of the gasoline responsibly.
Replace the fuel line between the tank and the carburetor.
Put fresh gas in the tank. See how long it runs.
While you're at it, change the oil and remove any debris from
the cooling fins on the engine. It may be overheating.
If it still doesn't run, you probably failed to replace the fuel line.
Trust me, this is part of good maintenance for these machines.
Sep 24, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
What do you need to take apart to get to the top of the gas tank to replace the fuel line Craftsman 200 MPH Gasoline Blower/Vac.
The left side but be careful there are alot of screws and the trigger mechanism they can be a pain if you dont feel comfortable then go to your local small engine shop.
Feb 12, 2011 | Husqvarna Craftsman 200 Mph 430 Cfm Gas...
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman leaf blower Model # 358794761
Sounds like you have dirt in carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Oct 17, 2009 | Craftsman Garden
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Garden Logo
151 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
