My Sony CCD-TRV138 will not play my recorded tapes. Upon pressing play, I get reinsert cassette message, I remove it and reinsert and always the same message. Any ideas???
Comments:
Sep 24, 2009
- I slapped it a couple of times and it did remove the "message" but, it will not play the tape.
Sep 24, 2009
- The reinsert message has gone but a flashing triangle keeps blinking and the tape will not play. Tried another tape to be sure but still, no luck. Awaiting your ideas!
Sep 24, 2009
- The slapping eliminated the reinsert message but had a warning symbol. Resetting the camcorder seems to have solved the problem and I am (i hope), back in business. Thanks a million for the rapid solution and a job well done!.
Believe it or not all you need to do is smack the side of it a couple times and will work great again
Comments:
Sep 24, 2009
- Use a head cleaner and then reset the camera. The reset button is inside the little door
Sony Service Hotline at 1-800-488-7669
Remove the cassette tape from the camera, turn off camera, remove the battery, then turn the camera back on, then take a pen or pencil and push the reset button, that is below the volume buttons (inside the view finder area). Release the pen then turn camera off again, then unplug the cord and wait 60 seconds so that the residule electric current can completely drain from the Camcorder. After 60 seconds, power on the camera and before you do anything else *YOU MUST RE-ENTER AND SET THE YEAR, DATE, TIME before you go any further. This is crucial to your camera working properly. Then power off again. Power up one more time and this time try to record and playback and see if everything works ok
Sep 24, 2009
- The problem is that dust accumulates inside the compartment where the cassette is inserted. Clean the dust out of it with a high pressure air hose
Sep 24, 2009
- Use the Sony V8-25CLD optional cleaning cassette
Is this cassette one handy cam better or builtin memory one.In terms of RESOLUTION, convenience,...
(More)
Is this cassette one handy cam better or builtin memory one.In terms of RESOLUTION, convenience, durability etc. Further Sony Dealer here guided me that Cassette one Handycams have been discontinued and after aome time they will not be available at all. Is it true.
I have tried several cassette tapes in the camcorder. Each time I get a message that says please...
(More)
I have tried several cassette tapes in the camcorder. Each time I get a message that says please reinsert the cassette. The lock is not on the cassette and I tried a new one.
Sat unused for over a year, when charging and attempting to record, the picture has a high...
(More)
Sat unused for over a year, when charging and attempting to record, the picture has a high disruption of colors and fuzzyness
i use to record a lot of footage of my friends and the audio was working fine when i was first using...
(More)
i use to record a lot of footage of my friends and the audio was working fine when i was first using it. When i took it out to watch the video i hear nothing but see everything perfectly. The sound stopped working.
