Question about Compilers & Programming Tools
Storing data in ms access with vb
Disappears data in time storing in ms access with visual basic
2 Suggested Answers
  • 3 Answers
SOURCE: how can i print datas from MSFlexGrid in VB6
I hear a lot of people are asking that question. I am sure its possible.
Try this:
For i = 0 To Form1.MSFlexGrid1.Col
For j = 0 To Form1.MSFlexGrid1.Row
Print Form1.MSFlexGrid1.TextMatrix(i, j)
Next j
Next i
That should move the data. I think. This isn't my best area; however, It doesn't hurt to try it right?
Hope it helps.
Posted on Nov 22, 2008
SOURCE: free visual basic source code salary database sample
i ask about code programming of for database connect words with signes of deaf
Posted on May 11, 2011
0 characters
1 Points
I dont know the disadvantages of visual basic.
visual basic, is only a basic programming language, most programs will run on Java script, microsoft is visual basic though, but it uses a lot more complex scripts then, if you like the programing language, go for it, but i did not like it.
VB is undoubtedly the simplest and easiest platform to build major Windows applications. The problem is that like other Microsoft products they change faster than I change my socks.You will certainly need more than just VB. Get into server and client side scripting and the use of VB Net.
Jul 06, 2010 | Microsoft Visual Basic V6.0 Fundamentals...
Retrieving acess data which is password protected thru VB
You will need to use a connection string. But - before you can configure the string correctly, I'd need to know how the data is stored (Access, SQL, ODBC, etc). You can find examples online. Just know that you are looking for "Connection String." Here's two examples:
1. For MS Access (Jet files):
' Set up the connection string.
m_strConn = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & strDestDBPath & ";" & _
"Jet OLEDB:Engine Type=5" ' NOTE: Use Type=5 for Jet 4.x.
2. For SQL database:
g_strADOConn = "Provider=SQLOLEDB;" & _
"Data Source=SERVER_NAME;" & _
"Initial Catalog=DATABASE_NAME;" & _
"User ID=mssql_userid;" & _
Apr 22, 2009 | Microsoft Visual Basic 6.0 for PC
How to access data from ms access with buffer in class code with vb application
Use ADO and create a connection string for a Jet file (version matters here when creating the string). Then use ADO commands and return recordsets to buffer your data.
Mar 26, 2009 | Microsoft Visual Basic 6.0 for PC
Microsoft Access query in VB
first you need to create a record set to do this, after creating a record set RS1. please follow the code below:
Update the code as per your requirement.
Rs1.Open "Select * from table_name where UserName = '" & UName & "'", Cn1, adOpenDynamic, adLockOptimistic
Mar 14, 2009 | Microsoft Visual Basic 6.0 for PC
How to Export Listview Data in Crystel Report through VB 6.0
Dear friend you can get your answer easily in
This website is all about .NET programming and VB and by a simple search you'll find your answer
Good luck
Feb 27, 2009 | Microsoft Visual Basic Professional...
How do i download Microsoft Visual Basic 6.0?
Search that in the google " free download ms vb 6.0 version" try that...
Feb 26, 2009 | Microsoft Visual Basic 6.0 for PC
Write into excel format
Your code does not save in access format it just makes a copy of existing file. You need to open table by table and export data using csv format.
It can be done using access OLE to export, or
write some VB code to access the database tables via ODBC and save row data to csv file
Feb 17, 2009 | Microsoft Visual Basic Professional...
Time ocx
try this
or try this also
it might help u good luck
Jan 27, 2009 | Microsoft Visual Basic 6.0 for PC
Compilers & Programming Tools Logo
22 people viewed this question
Top Compilers & Programming Tools Experts
Robin Hill
Robin Hill
Are you a Compiler and Programming Tool Expert? Answer questions, earn points and help others
