Question about Technics SC-DV290 System
The time delay fuse blew...I need to replace it but list the fuse
I jus realised you both think I'm talking about the fuse on the plug...I was refering to the fuse inside the stereo, I had it with me but I can't seem to place it any longer hence the question, I can remember it was a time delay fuse, 250v...maplins do them, I just wanna know which one
    Novelist:
  • 169 Answers
Fuses are designed to protect systems, TD fuses are also termed AS (anti surge) these are designed to absorb the surge from the transformer or other components within the amp.
It is very important to replace the fuse with the same size and type, as this will maintain the systems safety design. Wrong size and type of fuses can cause fires.
Now, it is possible that the circuit board has an ID (indentity print) on it, have a good look with a torch, it may well be marked. If not then contact the maker support team they will be able to help you. have the size (20mm or 1.25inch) ready, the model and serial number of the amp ready when you call anybody for help.
Hope this helps, thanks for using FixYa
Posted on Sep 24, 2009
How do I test a control (circuit) board?
You really can’t test a control board, but if you have a separate oven board there is a fuse between the two.
Sep 25, 2017 | Kitchen Ranges
2005 Saturn Vue Repetitive Ignition Fuse Failure
I think there is a short in the system, possibly happened while replacing the main brain.
Jun 19, 2012 | 2005 Saturn VUE
I think I might have blown my front speakers....they come on sometimes n other times they don't....idk where the fuse might be or if I jus need to replace the speakers all together....not sure and need...
speakers dont have fuses door speakers quite often develop this fault and it is common for the wires to break between the car body and the door to test put on the radio open the door and work the wires up and down the wires will be in a rubber sheath
May 30, 2011 | AudioTrak MAYA 44 USB External Sound...
I think I blew a fuse in my 1997 Isuzu Trooper. My ABS light came on as well as my power windows stopped working, and my rear defroster as well as mirrior defroster. This has happended in the past and a...
Locate your fuse box/panel, there should be a listing of all fuses on teh fuse box cover or in the owners manual. I would visually inspect one fuse at a time pulling out and verifying all are good one by one as well as replacing the master fuse. I hope this helps you.
Oct 27, 2009 | 1997 Isuzu Trooper
Hi greg talking. my drl on my 01 gmc has had a problem for some time now. i replaced the bulb sockets due to burn out, yet i still have no lights. i have gone through all the steps in my oweners man.....
chances are you will need to replace the fuse becasue the burnt socket shorted out and blew it but dont just check the one listed as day time running check all fuses it is not uncommon for power to run through other circuts and wiring.
Dec 11, 2008 | GMC C2500 Cars & Trucks
Fused plug
If it is a moulded plug you will need to chop it off and wire on a standard 3 pin plug(if you are qualifiedor capable of doing so ) If its in guarantee though do not do this. There must be a reason it blew the fuse. If in guarantee get it repaired under the terms of the guarantee.
Oct 22, 2008 | Krups FBC112 1600 Watts Toaster Oven with...
No power on Compaq MP2800 Microportable Projector
I am currently struggling with this issue.
There is an easily-accessed fuse inside the projector.
I was very excited to discover this last night.
However, before you get you're hopes up (as I did) remember: If the fuse blew, something else probably went first. After buying and replacing the fuse today, I realise that I need to replace or repair the power supply as it pops the fuse every time.
Here's how to get to the fuse:
Take off the lamp.
Now, looking at the projector from the back, you need to remove the left hand side panel.
This involves taking out 2 screws from that panel, 2 from the bottom and the 2 video connector hexagonal bolt things that are also in that panel.
The panel sort of hinges off, starting from the bottom.
You will see the fuse in the bottom right corner where the power lead goes.
It is a slow-blow (time delay fuse) so get the exact same one to replace it. A pack of 10 cost me €4.19 in Maplin, Galway, Ireland.
Anyways, this did not do the job for me... the power supply set the fuses off like fireworks and also blew a few in the socket plug as well (I don't think US readers will have those)
I will let you know how I get on with the power unit....
Good luck to ye!
Sep 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Technics SC-DV290 System Logo
320 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
