Question about Sharp LC52D65U 52 in. LCD TV
Once my lamp burns out is it replaceable - Sharp LC52D65U 52 in. LCD TV
  • 405 Answers
I've seen lamps go bad after just few hundred hours, normally it would be just one lamp and it is replaceable.
Posted on Oct 24, 2009
  • 834 Answers
You have a very long time before that happens
but yes they are floresant bulbs usually the inverter will go out first you have years on life
Posted on Sep 25, 2009
Replace lamp pt 61lcz70
make this steps and fix it. God bless you
  • Check the fan. Once the television is turned off, it is just normal for its fan to become louder. A projection TV actually depends on its lamp, which requires cooling so that it will not prematurely burn out. If the room where your TV is placed is very hot, the fan would also continue to run.
Replace projection lamp. To properly do this, make sure that the lamp's bulb has cooled down and the TV is unplugged. Carefully remove the cover of the lamp's compartment using your screwdriver (Phillips-head). Unscrew the sealed part of the lamp that can be found at the television's rear part. Take away the old lamp cartridge and then insert a new one. Seal the lamp with screws, replace its cover and then screw tightly.
Jul 31, 2013 | Panasonic PT-61LCZ70 Television
Burned out lamp RCA DLP TV Mod # HD50LPW165YX4 lamp type B
you can get the replacement lamp cartridge from the following link which also has installation instructions. Your model uses the 265866 lamp assembly.
http://www.tvrepairworld.com/rca_dlp_lamps
Aug 04, 2012 | RCA Televison & Video
Just replace the lamp.. there is a burning like smell, does anyone know what is causing this smell?
After the projection lamp was replaced the tv work fine right?The burning smell,is the burning carbon from the dead projection lamp.
Oct 06, 2010 | Mitsubishi WD-Y57 57" Projection HDTV
The first lamp "burned out" after only half a year of use and we only used it once a week. We bought a replacemente lamp and it burned out after three weeks... Someone plugged in the projector, the lamp...
The early lamp failures are due to poor air flow or longer hours of use.
So take care to clean the filters, see that the lamp brigtness is not put too high and reduce the hours of continuous use.
Sep 29, 2010 | ViewSonic Office Equipment & Supplies
Head lamp keeps burning out. replaced head lamp at
You either have a bad ground or the bad electrical connection at the light socket is "simulating" a bad ground. This is putting a high resistance on the bulb and it's taking it's toll by burning out the bulb. I would start with a new socket, and CHECK the ground. If you still have the issue, I would run another complete ground wire and not even worry about checking the ground itself. the Stick
Dec 10, 2009 | 2006 Suzuki Grand Vitara
The fuse has burned out in my projector benq MP610. So I opened the projector to replace it : same result. I verified, the lamp is also burned out. Do you think the burned out lamp can make the fuse to...
before a lamp blows it draws more current than it usually uses, but since it uses dc, it couldn't blow the ac fuse. but if the regulators on the ballast or power supply were bad, it would blow the lamp and draw ac power, possibly blowing the fuse.
Dec 02, 2009 | BenQ MP610 Multimedia Projector
How do I install a new lamp? It's a 62HM95.
Its relly easy to replace Lamp Look on your TV for a small Panel that you can remove without having to take the whole back off but if you have to just remove the whole back Lamps most of the time have 2 screws holding them to chassis once you know the location of Lamp and have small handle you can pull out if you are ording Lamp with out housing make sure you wear rubber gloves you do not want your fringer prints on new lamp what so ever! you can burn prints into Lamp once it gets hot Once you have new lamp install make sure back is on before turnig on.
Nov 19, 2009 | Toshiba 62HM95 62" DLP HDTV
Infocus x2, the bulb melts the small square lens even w/ fan on
either the ballast is bad and is sending too much current to the lamp, the lamps are a cheap knockoff, the thermal fuse is altered, and/or one of the fans aren't working.
Jun 14, 2009 | Optoma EzPro 738 Multimedia Projector
TV turns on but produces no visual or audio. Screen just stays black
Your lamp is burned out . I have a 52" hitachi lcd as well, and i have hadd to replace the lamp once a year. its a mercury based bulb which emulates alot of heat and if your exhaust fans are not working properly it will cuase it to fail or burn out more frequently than it should. cost is @ $120.00 for replacement bulb
Apr 12, 2009 | Hitachi 50UX52B/53K 50" Rear Projection...
Samsung 56"TV lamp burned out
The lamp replacement is a do it yourself fix.
Feb 24, 2009 | Samsung DLP HL-P5663W 56" TV
Sharp LC52D65U 52 in. LCD TV Logo
128 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
