MITSUBISHI TV STOPPED WORKING
WAS WATCHING A MOVIE WHEN THE TV TURNED OFF AND WOULD NOT COME BACK ON AGAIN. POWER BUTTON CLICKS WHEN PRESSED AND GREEN LIGHT BLINKS AND TURNS OFF. NOTHING ELSE EXCEPT A SLIGHT HISSING SOUND. ?????????????
  • Anonymous Nov 18, 2008
    I was watching TV when it just went "off".  It will not go back on.
    What should I do ?
    Genius:
  • 1,153 Answers
If you can do self test diagnosis, read threads here on Mits, or goto ctechnicians.com
Posted on Dec 16, 2007
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Apr 13, 2010 | Samsung S1050 Digital Camera
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Lg. screen tv mitsubishi HDTV 1080 SERIES INTEGRATED
i went to turn on the tv and the power button don't work
Jun 02, 2008 | Televison & Video
My widescreen tv...
I purchased a 32" ilo widescreen back in Oct. of 06. It worked great for about a month before I had similar problems as you're having. Suddenly my remote wouldn't work (except the power button) and none of the buttons on the TV itself would work (except the power button). I was able to watch movies but unable to switch the video over to TV mode. Very frustrating. The Walmart in my area wouldn't take the TV back. The only way I was able to get it fixed was by sending it to ILO's service center. (800) 216-5156. Fortunately less than three months had passed since my purchase plus I still had my receipt. Because of this they were willing to fix the problem free of charge. If more than three months have passed I believe they charge for labor costs but not for parts. Once I sent my TV out ILO had it fixed and back to me within three weeks. Luckily I had another TV around while I waited. I hope this helps.
Jun 04, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
373 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
