Question about LG WM2301HW Front Load Washer
I recently purchased an LG WM2301HW washing machine. I was wondering if this particular unit automatically controls the temperature of the water on a particular cycle or if the warm water needs to be adjusted from the inlet taps. For example, I'm washing a load on the warm temperature cycle right now. I just reached in to test the temperature and it is cold! It certainly isn't anywhere near the approximate 100 degrees that a warm cycle should be. If I have to adjust it from the inlet taps, do you have any good suggestions as to HOW I should go about accomplishing that feat? It isn't as easy as a top load washer, obviously.
    Top Expert:
  • LG Master
  • 48,346 Answers
Page 22 of the user manual states that warm rinses are regulated at 86F (30C) it states that there is a heating element as well to boost the temp to normal hot water temperatures (90-100 C)
Posted on Apr 11, 2017
SOURCE: LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
Posted on Sep 02, 2008
  • 547 Answers
SOURCE: LG Tromm WM2277HW Water level to low
this is normal the pic are all photo shop water you clothes are clean right?
Posted on Feb 12, 2009
  • 558 Answers
SOURCE: Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Posted on Apr 07, 2009
  • 105 Answers
SOURCE: LG WM2487 front load washer spews suds out of port on rear.
You are likely using too much detergent or the detergent is not high-efficiency detergent. Change detergents and/or lower amount and this problem should go away.
The water port on the back allows air inside the tub to escape. However, if the wrong type or quantity of detergent are used, excess suds will flow from this port.
Posted on Aug 02, 2009
  • 15 Answers
SOURCE: Water filter at inlet hose on LG WM2016CW
Why not try to clean these with a little CLR lime and rust remover and see if that does the trick....
Posted on Sep 06, 2009
Kenmore Elite HE3 does not work with Pure Wash system
One of the things to try is get a Y connector for the machine. Hook both ends of the Y to the washer at the hot and cold, then connect the last part to the pure wash. The HF error is HOT FLOW so it is not seeing any hot water pressure. The actual temperature should not be an issue. Also if you have too much water pressure you wont see the bubbles. If that happens just start turning down the cold water valve on the connection to the pure water unit until you see bubbles in the viewing window. I ams sceptical about these machines because you have to reduce the surface tension of water in order for it to clean, that is partly the job of heated water and laundry soap. Also if there is an ozone generator in that unit, there is a consumable part because ozone needs electrolysis to be generated. I cant help but wonder where the hydrogen goes when it is generated.
Feb 26, 2014 | Kenmore Elite Washing Machines
LG washer model wm2301hw won't turn on
We had the same problem (washer would not turn on). The problem was a small fuse blown in the power noise filter unit. The unit is a plastic block near the top of the washer on the inside - connected to the power cord. It is a very commonly produced unit and goes in a number appliances. The fuse inside fails frequently (so I hear) and is extremely difficult to replace due to the protective-covering material so it's easier to just replace the whole unit. I purchased a replacement unit for about $30.
Very easy fix:
1. Unplug the washing machine.
2. Take off the top of the washing machine (two screws in the back)
3. Identify the noise filter unit (top of washing machine, hanging on the right with the power cord attached to it).
4. Remove with one screw and unplug the two cables going into the noise filter unit. Slide out the unit.
5. Put in new unit. Screw it in, and plug the two cables into it.
6. Put the top of the washing machine back on (not necessary to test if the new unit works)
7. Plug in washer and run.
Oct 18, 2012 | LG WM2301HW Front Load Washer
LG washing machine loud and error code LE
Here is a tip that explains what the LE error code means.....
LG Washing Machine LE Error Code or Fault Code
Jul 02, 2011 | LG WM2301HW Front Load Washer
Lg washer when filling water pours on floor
Pull the drawer out and look inside the dispenser for any obstruction in the back of the tank.
Good luck
May 29, 2011 | LG WM2301HW Front Load Washer
Water continues to fill the tub even when the machine is off! Our water supply valve is the only way to make it stop filling!
This is symptomatic of a malfunctioning (not closing completely) water control valve- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 29, 2011 | LG WM2301HW Front Load Washer
OE problem
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Feb 19, 2011 | LG WM2301HW Front Load Washer
My LG WM2301HW is not putting water into the washer. Please advise.
the inlet valve is mechanically jammed shut so when the controls tell it to let water in it cant because the valve is jammed shut.need a new valve.
Jan 11, 2011 | LG WM2301HW Front Load Washer
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine water not hot enough
This so called "energy saving" ...That's why they build in this nonsense. Some dumbo in some office somewhere just thought it up thinking that will save the energy. I fact ,that way I have to wash same stuff twice because water is not hot enough ...
Apr 07, 2010 | Whirlpool WTW5300SQ Top Load Washer
I purchased a front loader washer and I only have a cold water line no hot,I hooked it up and the machine comes on but no water comes in the machine....can someone please help me figure this out??????
ok no problem where going to try this but your going to have trouble in the end...since you only have a cold tap ,,use a y hose to booth vavle dont cap of the hot,,,now you purchase a unit that has atc,,automatic temperature control..meaning the unit control how hot or cold the water will be in degrees,,,when you start the unit it puts hot in at the start even in a cold wash to break down the soap in the dispencer,,it doent know if you use powder or liquid,,so it just shots hot water though for a few second,,now that comes back to the begging,,if you put clothes like whites and that atc does nt sense that hot water the unit will stop until it do,,and you will get a code,,im here onthejob
Jan 02, 2009 | LG WM1814CW Front Load Washer
LG WM2301HW Front Load Washer Logo
101 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
