Question about Stanton C501 Dual DJ MP3 CD Player
Skipping and Jumping
Use at home no problem, test prior gig, no problem, moment start using it "live" hops, skips and jumps on channel 2 only all formats not just MP3. Using various CD's so not the cd, various cd's play ok in other devices so not cd's.
It's as though there is a ghost in the place!
  • 1,512 Answers
Try CLEANING THE LASER FOCAL LENS with a cotton bus and windex. use a dry fresh one to remove any film after cleaning. IF problem persists, run machine on its end when mistracking occurs(may be hard if yo doing a gig). If the mistracking stops(because the top bearing in the motor is worn) then it may require a new spindle motor. A double check for worn bearings is a drop of 3 in 1 oil to the top bearing of the motor. If the mistracking stops, REPLACE MOTOR. Oiling it is just a short term solution and it will fail again.
If its not the spindle motor, you may need to REPLACE LASER ASSEMBLY I would do both for a commercial unit that does gigs. Where possible i also check the price of a COMPLETE NEW TRANSPORT. This way you get fresh load belts and tracking drive assly too. At any time replacing the laser, remember to check for(and remove) a solder short circuit across the laser diode to protect it from damage by electrostatic discharge. Do this after you have installed the loom if possible. And of course work electrostatic safe, at least GET A WRIST BAND while you are getting the spares.
Posted on Dec 16, 2007
2000 Mazda 626
Sixteen year old car with only 40K miles must not be driven often, or sat for some time. I would suspect fuel system issue, such as bad pump, clogged filter, bad regulator or faulty injectors. Start by testing fuel pressure.
Jun 20, 2016 | 2000 Mazda 626
Tsstcorp cddvdw sn 208ab cracking noise and skipping
The cd player needs to be removed to check for blockages or replacing as necessary.
Jan 09, 2014 | Toshiba Satellite Computers & Internet
Are there different names for jump roping?
Jump Roping can also be called skipping, rope skipping, or rope jumping. Skipping rope is generally the British way to say it, while Americans say Jumping rope.
Jan 03, 2013 | Exercise & Fitness
ViP612 DVR-HD poor play back of recording
kmej350,
Thank you for bringing that to someone's attention as I would love to help you with it! If you need the receiver replaced, you can feel free to email me your account number so I can see about getting a replacement shipped to you! My email address is michael.lemar@dish.com and I'll look forward to the opportunity of getting this taken care of for you so you can start to enjoy your programming!
Dec 18, 2012 | Televison & Video
When typing, the print head jumps up & down and skips spaces
Try it without the lift off tape they nsometimes jam the printwheel.
There may be a broken wire in the harness about 1" from the carrier.
DickyO
Nov 25, 2012 | Olympia Mastertype 3 Typewriter
Technics SC -HD 501 CD jumping and skipping
If this happens on all CDs then most like the drive is bad or lens is dirty You can try cleaning out the heads using a cleaner disc. If you have a way to get to the lens you can try cleaning it manually. But most likely. It's one of the following dirty lens, bad motor, bad speed control.
Nov 16, 2011 | Audio Players & Recorders
The timing belt keeps jumping and bending the vaules
If your timing belt keeps skipping teeth then you may need a new belt, a new automatic tensioner, or need to align the pulleys correctly before putting the belt on.
What happened prior to this problem starting?
Jun 23, 2011 | 1991 Eagle Talon
Is there a tracking system on this VCR? We have several tapes that are jumping or skipping. Sylvania 6240VD
All VCR's have tracking, it's not however clearly marked on the remotes often. Some use the up-down channel channel selector or other keys, while some have it on a menu somewhere.
It's also worth cleaning the heads sometimes with Servisol Video 40. Just take the top cover off and spray both the big video head and the smaller heads. Let it dry up before trying a tape.
Jul 30, 2010 | Sylvania 6240VD VCR
Skipping and Popping. 4.6 v8
It sounds like you have a miss fire event going on. look for spark jumping from the plug wires to the engine or any metal object. Best way to see is start you truck at night open the hood you should be able to see the spark jumping
Mar 29, 2009 | 2002 Ford F150 Regular Cab
Skipping :(
this is nothing to do with your laptop it's your'e connection speed that's obviously not fast enough or the site is heavy on downloaders causing a slow down of media downloads
Sep 05, 2008 | Acer Aspire 5315 Notebook
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Michial Gueffroy
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
