Question about Pasquini Livietta Espresso Machine
I need the directions on how to use this machine
    President:
  • 3,433 Answers
How to change direction of pitching arm on machine?
Have you contacted Iron Mike yet. Most small a/c motors only go in one direction. Need more info. Was it was working correctly, then changed? Or did you buy it used this way? If the machine is NOT turned off in the correct position, then restarted quickly, it will run backwards and jam up the chain. You may need a new motor. email me if needed, Steve Manookian Pitching machine repair, Los Angeles area, stevemanook@gmail.com
Nov 26, 2015 | Iron Mike MP-5 Pitching Machine
How do I change the direction that the arm travels on an Iron Mike Machine?
Iron Mike Pitching machines can be configured for baseball, fast pitch & slow pitch softball.
Aug 30, 2014 | Iron Mike MP-5 Pitching Machine
Attachment "Lock Cutter" for Singer model #1120
contact singer customer service about the directions you need
Mar 04, 2012 | Singer Sewing Machines
Can not pick up thread from spool
First check to insure that machine is threaded properly, and thread is not binding. Next check to make sure that needle is in machine properly (facing correct direction and fully seated) If you are still having problem check the bobbin case ( does bobbin turn correct direction when thread is pulled?) You will have to refer to your owner's manual to verify this as not all machines are identical (but usually the correct direction is clockwise) If still having problems you may have a problem with timing of the machine (usually after a bad fabric jam) If this is the case you will either need a service manual or need to take the machine to a qualified technician.
May 16, 2011 | Sewing Machines
I need a user manual of whirlpool semi-automatic washing machine
whirlpool semi automatic washing machin motar is rotating in only one direction (clock wice direction) ho to solve the problem?
Sep 22, 2010 | Whirlpool Washing Machines
My washing machin suddenly stop while I was doing laundry when it gt fill with water
After water filled, the machine will enter agitation mode. It stopped since the mechanism to engage the agitation to one direction of motor turning is not engaged. It is a helix nut to lock in the direction of motor turning (motor has 2 direction : one is for agitating and the other is for spinning). It is worn out and needed replacement.
Sep 20, 2010 | Kenmore Washing Machines
Need threading instruction for white sew ez plus childrens machine
Raise thread spindle by graspi G the expose s too and pulling up wears until thread spinale is fully extended, Place thread spopola on the three ad spindle. Pull thread from the thread on the thread spopola on the thread spinale and put it through the thread holder in the direction toward front of macchine. Bring thread a cross to the thread tension screw. Thread goes over the tension adjusting screw and must be position ed between the two washers beh ind. The tension adusting screw. This is what provides the lockstitch tension to the thread. Pull thread from tension adusti G screw guide through thread take up lever in the directions tovwarped front of machine. Pull thread through thread guide inserting in the direction tosare the front of the machine. pull thread down to thread guide and insert thread from the top downward. If necessary, loser the neede to reach this guide by turning the handwheelslightly counterclockwise (in the directions foward you) to loser the needle. Raise the need le to reach the eye by turning the handwheel slightly counterclockwise (toward you) insert thread through eye of the needle from the front toward the back of the machine ( use threader accessory if necessary) raise the presser foto by lifting up on the lever st the rear of machine. Pull about 10 inches of thread through the needle and lay it on the deck under the presser foot running in the directions away from you.
Feb 14, 2010 | Sewing Machines
Need a Site for my Singer Machine for directions/manuls
Here is a link that will take you to the site where you can download the manual that you need, right to your computer. I hope that this helps!
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/7462-_M
Aug 09, 2009 | Singer 7462 Mechanical Sewing Machine
When machine quilting sews fine when moving forward, skips stitches when moving away
Check your needle. Make sure it is not blunt, try a Size 90 Topstitch needle or Embroidery needle. If you are using a thread thicker than regular piecing weight, you need a needle with a larger eye and a larger scrarf - the hollowed out bit at the back of the needle. Also don't sew too fast nor change direction too sharply. If you need to do a sharp turn, let the machine "mark time" once at the turn before moving off in the new direction.
Pam
Apr 28, 2009 | Sewing Machines
Juki MO-2516N motor runs in reverse
This machine as an AC motor which only runs in one direction no matter how the leads are attached.
Why do you need to reverse the motor direction?
Feb 01, 2009 | Juki MO-655 Mechanical Sewing Machine
Pasquini Livietta Espresso Machine Logo
73 people viewed this question
Top Pasquini Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
De Brewerz
De Brewerz
Level 1 Expert
Are you a Pasquini Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
