Question about Nikon Coolpix S560 Digital Camera
How do you change the iso sensitivity? - Nikon Coolpix S560 Digital Camera
How do I change the iso on my nikon coolpix p50 camera?
First of all, you need to be out of the point&shoot modes. Those modes are designed to let you point the camera and shoot, with very little control over the resulting picture besides the framing and timing.
ISO sensitivity is in the Shooting menu. Rotate the mode dial to P, M, or Hi ISO, then press the MENU button. Use cursor-up/down to select "ISO Sensitivity".
May 27, 2011 | Cameras
Kodak Z712 ISO
go to manual mode to change it sir.
Jun 15, 2008 | Kodak EasyShare Z712 Digital Camera
How do i unlock iso-auto on the s5 pro?
Hi dear chrisofoto, You can change the ISO sensitivity setting by pressing the ISO button and rotating the command dial, also the white balance by pressing the WB button and rotating the command dial to get the desired value.
Best regards
Mar 24, 2011 | Fuji FinePix S5 Pro Digital Camera
What is the ISO
The letters ISO on your digital camera settings refer to the film speed. Even though your camera is most likely not film at all, but rather digital, the ISO setting still does has the same function as older film cameras. ISO determines how sensitive the image sensor is to light.
Mar 06, 2011 | Kodak EASYSHARE Z1285 Digital Camera
Can't change ISO setting
You could scroll to sensitivity in the menu. However, to get the numbers you want, you'll need to switch to manual instead of auto.
Oct 28, 2009 | Nikon COOLPIX S700 Digital Camera
My pictures are dark even with the flash
The ISO (sensitivity) is set too low, like 200 ISO.
Change the ISO setting to 3200, or maximum just to see if pix become very light.
Normally, you might want to keep it around 800 ISO.
Sep 20, 2009 | Nikon D40x Digital Camera
Pictures are dark
Put in new alkaline batteries to test the flash. Don't use rechargeables or "heavy duty" for this test.
Aug 30, 2009 | Cameras
How do i change ISO/ASA on the nikon N65?
The ISO is automatically set by the DX code on your film canister - if there is no code, the camera sets ISO 100. If you load canisters yourself with, say ISO 400 film, you can adjust the exposure using the exposure compensation button at the top right side of the LCD ( " +/- " ). Using ISO 400 film set the +/- to minus 2 ( -2 ) so that it will UNDEREXPOSE 2 stops since the film is 2 stops ( 4X ) more sensitive than ISO 100 film.
Nov 18, 2008 | Nikon Cameras
What are the available ISO rating for the DiMAGE A2?
The DiMAGE A2 sensitivity can be set to Auto, ISO 64, 100, 200, 400, and 800. When Auto is selected, the camera automatically controls the sensitivity within the range of ISO 64-200.
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
ISO sensitivity
Yes the ISO sensitivity can be adjusted. The settings are, Auto, 64, 100, 200 and 400. Various scene modes will automatically adjust the ISO to compensate for the lighting conditions under which you are shooting.
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Nikon Coolpix S560 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
