Question about Olympus Mju Tough 8000 Compact Digital Camera
My camera keeps saying "card cover open" before operating the camera in water, please check the battery and usb covers for foreign objects" Ive checked and make sure they are closed but it keeps saying it and won't let me use the camera at all, not even to upload pictures.
silly girl
  • 513 Answers
SOURCE: "Card-cover open" error message
It's when putting the card in.. typically you put it in and it clicks (so to speak).. if you delay removing your finger-push, it does something to the card and makes a Disconnect, although in looking at it, it looks just fine.. and the cover closes... A lot of people are reporting 'door open' errors. The micro-switch in the door housing is quite sensitive and pressure shifts from your hand on the door can cause it to trigger as if the door were opened. some get progressively worse. One fix is to add a little bit of length to the plastic that contacts the switch, either a layer of tape or a drop of epoxy, etc. This may help (or may not if the switch itself is flaky). Another fix discussed bypassing the switch altogether, obviously not for the faint of heart (or cameras in warrantee).
Posted on May 08, 2006
Mix-it-up
  • 832 Answers
SOURCE: scanner cover open
Simply force the button front into position by pressing it with both hands.
In case your wont be successfull stick a thick tape at he position were the cover switch contacts the inner cover (opposite to the display towrds inward is a double plastic contact).
Posted on Oct 28, 2007
SOURCE: Olympus Stylus 770SW error message
After only 15 days mine did the same thing. I called the dealer Olympus and they gave me a RAN number and told me where to send it. I got a call about a week later. They said because the camera had moisture inside I was not coverd. The best they would do is mail me a rebate card for 25 dollars off my next purchase. I was like WTF. The woman said sorry but that was all they could do. When I asked to speak to manager she hung up.
Posted on Dec 05, 2007
SOURCE: My screen keep showing the Card Cover Open Error even though the cover is closed
The card door sensor is either damaged, failing or gone completely. You can take camera apart, (7 screws I think) take the back off. Sensor is at the back of camera near the battery door. If sensor is missing, you will see 2 spots on the electronics board where it was connected. Carefully melt solder so that those two points are connected. If sensor is still in place it's probably damaged. Carefully remove sensor using small snips or something like that, with out damaging anything around sensor. Then solder 2 points together. Good Luck
Posted on Apr 23, 2008
mastersaintx
  • 928 Answers
SOURCE: How to Get a Foreign Object out of Wii CD Slot?
You may follow the video at the link below. Please see it as soon as possible.
http://www.metacafe.com/watch/757800/opening_up_nintendo_wii/
Posted on Sep 06, 2008
Why does my camera lens extend properly but the lens but won't open
  • mechanical problem or the lens cover is jammed check the fron cover if there is any foreign object obstructing the cover .
  • have it checked in your nearest service center
Aug 21, 2014 | Canon PowerShot Cameras
I have an Olympus stylus 720 SW, when I turn it on the lens cover either won't open or opens only partly.
1. Sand or foreign object in the lens cover.2. bad motor or gears.
Try cleaning with canned air while powering the camera up/down...
Mar 18, 2012 | Olympus Stylus 720 SW Digital Camera
The description said it was an underwater camera but once i took it underwater it turned off and will not turn on.
Welcome to FixYa.
Before using the camera in under water, you have to secure that battery cover,card slot cover snd DC IN terminal cover are completely closed to prvent water from getting inside the camera and damaging it. Please note that the camera accessories are not waterproof.
Yes, Sanyo VPC-WH1 High Definition Camcorder is a waterproof camcorder, however you can not used it in all types of water. Below are the Cautions concerning use in water.
* The waterproof properties of the camera apply to fresh water and saltwater only. They do not apply to cleaning substances, chemicals or water from spas.
* Do not immerse in water at a depth greater that 3.0m (9.84ft)
* Do not subject the camera to high-pressure water.
* Do not immerse in water for longer than 60 minutes.
After 60 min. of use in water, allow it to dry for at least 10 min.
* Do not immerse in water that is warmer than 40 degree C.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover with wet hands.
* Do not open and close the battery cover, card slot cover or DC IN terminal cover on the beach or at the poolside.
* Do not jolt the camera while it is immersed in water. doing so may cause the battery cover, card slot cover or DC IN terminal cover to open.
And one more thing that you have to do is to chaged/replaced the waterproof seals every year with new ones. For replacing the seals, please consult your dealer and take note that there is a fee for replacing the waterproof seals.
I hope this information will give you an idea on how to use your camera under water.
Feel free to send us your comments and suggestions.
Thank you for using FixYa.
Apr 06, 2011 | Sanyo VPC-WH1 High Definition Camcorder
Have an Olympus Stylus Tough -6000 digital camera and when I turn it on a message appears on the screen that says "card-cover Open" and it won't allow me to operate the camera. The problem is...
remove the batteries and the card from the camera and clean it with something smooth and dry ...after that reinsert the card in th ecamera several times until it is recognised..this happens when the card it is not proper inserted ..or something is meesing with the sensor that detects the cover position...so a gentle cleaning inside will help also..
Dec 21, 2010 | Cameras
Canon mp470 keeps telling me there is a paper jam
Hello my friend,first thing we are going to check is if its a jam inside from a foreign object.So
  1. Power the printer off.
  2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder.
  3. Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer.
  4. Close the scanning unit (printer cover).
  5. Power the printer on and confirm that the printer operates normally.
But in this procedure be very careful and don't push hard anything!
Jan 31, 2010 | Canon PIXMA MP470 All-in-One Printer
DCP 115C does not print
Check for foreign objects, such as a clip or ripped paper, inside the machine.
Open the scanner cover by pulling up on the lower right corner of the cover. Look inside the machine and remove any foreign objects. If you see jammed paper or another item inside this area, gently pull it out and then close the scanner cover securely
the manual states for this problem
"The machine has a mechanical problem.
OR
A foreign obstacle such as a clip or ripped
paper is in the machine."
Aug 05, 2008 | Brother DCP 115C All-In-One InkJet Printer
Dec 04, 2007 | Olympus Stylus 770 SW Digital Camera
Slr camera's lcd screen only says i have taken 3 pictures, and keeps sayin ERROR, what could be wrong? I tried replacing the batteries and the camera still says ive only take 3 pictures, even when i out...
Try resetting the counter by pushing and holding the two rewind buttons simultaneously ( red symbols ), one on each side of the top cover. Then open and close the film door.
Sep 23, 2006 | Nikon N65 QD 35mm SLR Camera
Olympus Mju Tough 8000 Compact Digital Camera Logo
90 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
