Question about Garden
Water pours out the other end of the pump opposite the pressure hose connection. It has a clear plastic cap with a small **** in it. Looks like water should escape here but way too much water being pumped out.
  • 97 Answers
SOURCE: Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Posted on Mar 19, 2009
  • 1388 Answers
SOURCE: Had the Northstar 3000 psi Pressure Washer for 2
It is easy to check if your hose and quick connects are supplying enough water to the pump. Your pressure washer gallon per minuite requirements are printed on the machine and also on the pressure tips in GPM. Your post indicates 2.5 gpm but check your documentation of GPM. Next remove the tip from the wand and connect your hose with current quick connects to the machine. Start engine and direct the pressure wand into a bucket for exactly one minute. Measure the amount of water in the bucket, it should be very close to stated gallons. Do the same test with tip installed and compare measurement. If pump is starving for water you will not get proper amount of water in the bucket and the water hose will collapse. Two to four gallons of water per minute is not very demanding and should be delivered even with very small opening. You can even just direct the hose into the bucket for one minute and check how much water your hose is capable of delivering. I believe that you will find no problem with water delivery to pump. I would certainly enlighten Northern with your findings and question their evaluation. When you start using your pressure washer again try using it at lowest pressure to get the job done. Lowering the pressure to about 75% of max will increase the life of the pump and engine. Good luck with you pump
Posted on May 10, 2009
SOURCE: Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Posted on Aug 14, 2009
  • 243 Answers
SOURCE: low pressure
hi some valves at cat pumps need a 100 psi pressure to open and close correct. when there is air in the pump the valves wil not open and close till air is bleeded. take of highpressure hose, open watertap and bleed pump till no more air comes out. reconnect all hoses and try again. if there is no more air in the pump and its still not working, i should think its the pump.
Posted on Feb 16, 2010
  • 623 Answers
SOURCE: Water is not coming out of my honda pressure washer
Any chance it froze during the winter? They do need to be winterized.
Posted on May 05, 2010
Worcestr Greenslave 18/25 - have increased pressure and fires up ok but locks out after about 2 mins each time. Any clues?
Ensure pump is working. Remove end cap [usually silver and same size as little finger nail] check with small screwdriver held lightly into the pump body that the pump is rotating. Water will drip out protect from this with cloth. in the combustion chamber there is a flame detector, usually at the back it looks like a thick wire sticking up about 1-1/12 inch. Clean this with medium 120 grit sand paper AND clean out the gas holes in that area. a tooth brush is good. Vac out the dust if you can Small hose pipe connected to vac nozzle
Mar 15, 2014 | Water Heaters
Losing a lot of coolant. I don't see a leak. I started to drain the system and it smells burnt to s**t. What might my problem and possible solutions be?
see this causes and fix it. God bless you
Water pump -- A bad shaft seal will allow coolant to dribble out of the vent hole just under the water pump pulley shaft. If the water pump is a two-piece unit with a backing plate, the gasket between the housing and back cover may be leaking. The gasket or o-ring that seals the pump to the engine front cover on cover-mounted water pumps can also leak coolant. Look for stains, discoloration or liquid coolant on the outside of the water pump or engine.
Radiator -- Radiators can develop leaks around upper or loser hose connections as a result of vibration. The seams where the core is mated to the end tanks is another place where leaks frequently develop, especially on aluminum radiators with plastic end tanks. On copper/brass radiators, leaks typically occur where the cooling tubes in the core are connected or soldered to the core headers. The core itself is also vulnerable to stone damage. Internal corrosion caused by old coolant that has never been changed can also eat through the metal in the radiator, causing it to leak.
Most cooling systems today are designed to operate at 8 to 14 psi. If the radiator can't hold pressure, your engine will overheat and lose coolant.
Hoses -- Cracks, pinholes or splits in a radiator hose or heater hose will leak coolant. A hose leak will usually send a stream of hot coolant spraying out of the hose. A corroded hose connection or a loose or damaged hose clamp may also allow coolant to leak from the end of a hose. Sometimes the leak may only occur once the hose gets hot and the pinhole or crack opens up.
Sep 28, 2012 | Cars & Trucks
The sprayer nozzle is stopped up, i have tried cleaning it out and it still won't spray.
Round up 1.33 Gal Spray can have a bad pump or a clogged filter or both.
Test pump: pump the handle, does it get harder to pump after 10-15 pumps, when you open the cap does air rush out? If yes, pump is good, if not, wear rubber gloves, remove pump/cap assembly, remove inner tube from cap, the handle\ pump plunger will remair with the cap. if the o ring is dry, wipe it clean, put a little petroleum jelly on the plunger o ring To Lubricate it and prevent o ring wear and helps it seal air tight so the pump will work correctly. reassemble handle\cap make sure the Black inner black plastic hose aligns with the white spray hose .
If your pump passed the pump test, lool inside tank at the chemical fluid clean or does the fluid look like it has lumpy white clumps in the fluid, if so, empty fluid in tank into a clean throw away container look at rinse the tank out with water, strain the clumps out with a paper towl draped over the tank opening inserted about 2 inches into tank opening then when you slowly pour the fluid back in hold both end of the paper towel so it does;nt fall in tank the clumps will remain on top of the paper towel , Then your ready to clean the filter in the cap. Remove the black plactic tube from the pump, remove the white out side hose(squeeze the black connector to unlock the white hose , Then look in the hole the the black tube was inserted into, look for clumps (looks like lint from a clothes dryer, about the size of cotton ball, ) in that hole, to clean the clogged filter,I used low pressure air from an air tank, Blown into the hole where the white discharge hose was mounted. The clog should fall out of the opposite hole where the black tubs mounts. Reassemble and test, Also, the white spray tip turns out to change from spray to stream. Wash Hands good the chemicals can soak into your skin, some people are very allergic to the fluid
Jul 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
My karcher seems to pulse when on, could this be due to the low water pressure from the hose?
I do not have specific experience of your machine.
However, the high pressure pump will be controlled by a pressure switch on the high pressure outlet to the pipe and jet.
Pulsing (turning off) suggests that the outlet (high pressure) pipe is blocked or partially blocked. Try checking the nozzle and (with the unit turned off) clearing it with a fine piece of wire.
Hope this works
Nic Williamson
Apr 23, 2011 | Karcher K2.26 Electric Power Washer
Overheating
I had the same problem with my Suburban. I was loosing water. Turned out to be a small crack in the plastic end cap just below the neck where the hose attaches. Had to replace the radiator which was not very hard. You should start with a pressure test of the system to see if you can find a leak. Some autopart stores will do this for you. Also have them check your pressure cap. You should also look at the water in your radiator to see if it has any rust or oil in it. If none of this reveals the problem the next thing to do is replace the thermostat. They are cheap and can cause problems after 100k miles. I is under the neck fitting on the engine where the top water hose attaches. If you still have problems then it may be change the water pump time.( Check the belt first) Water pumps usually have a small hole in the bottom of the housing which will start leaking water when the pump is going bad. If it is dripping water when the engine is running and hot then it is time to change the pump.
Good Luck
Nov 24, 2010 | 2005 Chevrolet Suburban
My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
Good news, your engine runs
But your pump may be bad
Here's how to test your pump
Check oil as outlined lower down
Disconnect the washer hose and gun
Connect water hose and turn on water and water should pass straight through the pump
Look for clogs in the hose-end where water hose connects to machine
Turn on machine and see if water shoots out pump
If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
Look for clogs in the end of each water connection.
Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
Finally, the gun trigger mechanism may be bad
I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
Check your pump oil
Pump oil is SAE20 or SAE30 non-detergent motor oil
Pump should be no more than 1/2 full of oil
Use plastic hose to drain pump oil
Do not turn machine on its side or turn machine over or engine oil will run into carburetor
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Water over flows think its the water sensor
It's likely just the hose to the pressure (water level) switch that has come loose or fallen off. Remove the console screws and flip back the console to get access to the pressure switch and the connections. If the connection end of the pressure switch hose looks "stretched", trim 1/4" off and re-seat it.
If the hose looks ok (no cracks or splits), check the other end of the hose which connects to the side of the tub.
The see if the pressure switch is faulty, remove the pressure switch hose and attach a small hose to the pressure switch. Blow into it gently and listen for "clicking". Test with a fill to see if the switch shuts off the water valve.
Let me know if you need more assistance. If so, please post your model number.
Apr 08, 2009 | GE WBSR3140DW Top Load Washer
Water keeps flowing non-stop with my old Kenmore washer
Check the pressure switch and the pressure switch hose.
Remove the end caps on the console and remove the 2 screws that hold it down. Pull slightly from the bottom of the console and flip it up. On the left side you should see the pressure switch (water level switch) with a few wires and a small hose connected to it. The hose should be connected between the pressure switch and the tub. In most cases the pressure switch hose sometimes falls off over time due to vibration.
Replace the hose if it is damaged. If there are no visible holes or cracks in the hose, try trimming 1/4" off each end of the hose (pressure switch side and tub side) and reconnect them making sure to push hose ends securely onto connections. This is done because the hose sometimes stretches at the connection points and you will lose air pressure inside the switch, therefore the water will never shut off.
Alternatively you can use small clamps on each end.
If this doesn't work, check the function of the pressure switch by attaching a small hose to it and blowing lightly into the pressure switch while the machine is filling. You should hear a click and the inlet water valve should turn off. If it doesn't turn off you may need to replace the pressure switch or if the machine fills even when it's in the off position replace the inlet water valve.
Mar 03, 2009 | Kenmore 22422 Top Load Washer
Water coming from soap dispenser
We had water pour out of the dispenser of our Kenmore HE2 washer. hot water helped us for one load then i realize that a trapped rag was the problem We were actually able to pull the face cloth out of the intake tube without taking everything apart!
opened the washer door and feel around inside the rubber seals to find where the intake tube connects to the drum (upper-left side). felt a small bit of cloth sticking out of the tube and were able to slowly work it out by pulling back and forth. and pulled it completely out thats all it was try this fi
Feb 07, 2008 | Hotpoint Aquarius WD640 Front Load...
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
