Question about Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine
When I try to sew my machine jams a little every few seconds and is not sewing on top. When I try to remove the fabric it is stuck and there is a mess of thread underneath. I have cleaned and oiled my machine and the problem is still there. I think my tension is fine. Help!
  • 268 Answers
Although you already re-theaded and cleaned your machine, re-check this:
- Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your bobbin case. Re-thread your machine, reinsert and rethread your bobbin.
If that doesn't work, try this:
- Change your bobbin.There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
- Raise your feed dogs if your machine has this feature.
Note:
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Posted on Sep 24, 2009
  • jmvks Jul 31, 2011
    I had a problem with the thread breaking all the time, and was adjusting the tension to try to fix it. But it didn't fix it. Finally i decided to change the thread to a newer spool, and voila! Everything was fine. Could old, dry thread be the problem?
Hi, I own a Kenmore Ultra Stitch 6 sewing machine and I am having problems with the clutch wheel; it keeps popping off so although the machine is working it is not sewing (the needle does not sew) I have removed the outside small wheel outside of the clutch which has a washer and a silver wheel with indents (that I presume the "teeth" will be facing in) After I reasemble the parts and try to sew without any material it works fine (and I get very happy thinking i have fixed it, hah) but when I place material to sew and start sewing the clutch pops out and the needle doesn't move although I can hear the machine working (like it was in neutral) I am sure I am doing something wrong when I place the parts together and I need some ideas.
Posted on Mar 24, 2010
  • 3,600 Answers
Check to see if the needle is bent and check the cam timing is not loose.
Posted on Oct 17, 2009
Needle is picking up several threads from the bobbin after i have been sewing and jams
Remove the bobbin and case from the bottom. Try dusting it out and add a little oil. Also, check both top and bottom thread tensions. If that does not help then you may have a timing issue which requires a lot more technical expertise.
Aug 09, 2014 | Singer 3810
New 9960 Singer sewing machine keeps jamming
try a new needle-- one for the fabric your sewing
make sure the top thread doesn't come off the thread take up lever
make sure the bobbin is inserted correctly
if the suggestions don't help
take the machine back and tell them what it's doing and ask for another one
Mar 05, 2014 | Singer 9960 Quantum Stylist Sewing Machine
New 9960 sewing machine keeps jamming
try a new needle--the correct one for the fabric and thread
make sure the top thread has not come off the thread take up lever
rethread the machine top and bobbin-- using every thread guide
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help, then taking the machine to be checked would be a good idea.
Jones vx860
try a new needle--one for the fabric being sewed
try a different bobbin --make sure it's turned the right direction
could also be a timing problem
Oct 21, 2013 | Sewing Machines
Needle gets jammed in fabric!
make sure to use every thread guide it helps the tension
try a new needle--make sure it's the right needle for the fabric
being sewed
here's a free manual if you need one, just click on the link
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_XL_3025_3027_3030_EN_447.PDF
Dec 06, 2012 | Brother XL-3030 Electronic Sewing Machine
Thread is clumping underneath
Unfortunately, the machine's timing may have been adversely affected during the jam and removal of the fabric. Here's something that may resolve the issue if it is not timing-related:
Install a brand new needle.
Remove all the thread from the machine.
ALWAYS RAISE the presser foot when threading the top thread!
Rethread from the beginning and verify the thread path is correct.
If you have a smoothly-wound bobbin, try that. (A bobbin that you describe will contribute to sewing issues.)
Install and thread the bobbin--confirm the bobbin is spinning the right direction in the bobbin case.
Re-test your machine.
If you are having issues with the bobbin not winding smoothly, there are standalone bobbin winders for about $30 on the market (local JoAnn's or on the internet) called Sidewinder. Confirm that your machine bobbins will work (there are a few machines that won't, I think Singer). This is a very good accessory to have since you can wind bobbins without having to unthread the machine and also saves wear & tear on your machine.
Amazon com Simplicity SideWinder Portable Bobbin Winder
Simplicity Sidewinder Portable Bobbin Winder
Mar 24, 2017 | Kenmore Sewing Machines
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer CE-100 and I would like to know why it keeps beeping and stopping?
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
My ce4000 started jamming up thread under the foot and then it pulls the bobbin case and gets stuck so that it doesn't sew at all
If the thread is getting jammed under the FABRIC then it means the TOP thread is threaded wrong. Just the opposite of what we think it should be. If the thread is looping on the TOP of your fabric it's the BOBBIN thread that's not threaded right. If it's a front loading bobbin, the thread should go over the top of the bobbin to the right before placing it in the bobbin case. Hope this helps!
Aug 21, 2010 | Brother CE4000 Computerized Sewing Machine
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
Kenmore Drop-In Bobbin 16231 Mechanical Sewing Machine Logo
927 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
