Question about Yamaha HTR-5960 Receiver
Yamaha HTR 5960 Receiver No sound from Center channel
I followed the toubleshooting tips in the manual. Center channel setting and HI FI settings and there is still no sound. I connected the center chennel to th4e right speaker and the speaker works. Any ideas before I take it in for service?
  • 11 Answers
SOURCE: Yamaha HTR-5240 no sound from main speakers
check and see if there is a a/b,a+b setting for speakers make sure its set to a
Posted on Jan 06, 2008
Benimur
  • 6966 Answers
SOURCE: subwoofer
Hmmm, I think your Yamaha RXV640 does not have a sub woofer amp, it has a line level low pass output that needs to go to a separate/dedicated sub amp before going to a subwoofer.
Good luck and kind regards.
Posted on Jan 17, 2008
  • 151 Answers
SOURCE: No sound coming out of back speakers when watching DVDs
Make sure you have set blu ray player out put to bitstream,if you have set to pcm for hd master audio and dolby true you need to have a amp to decode this and hook up with a hdmi cable.If your amp has hdmi in and out but no high def audio you may still get multi channel audio.
Hope this helps.
CABLE GUY.
Posted on Jun 29, 2008
SOURCE: Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Posted on Dec 05, 2008
sodeep
  • 3267 Answers
SOURCE: My DirectTV HD remote won't let me control my
No it can't be done. The input level is automatically controled to give a fixed output at a predetermined level..........................sodeep
Posted on May 04, 2009
How do I reset my Yamaha HTR-5930 receiver back to the manufacturers settings
Hello there
A combination of 'standby' and 'straight' buttons
You follow the procedure on page 65 of the user guide
available to download here if you have lost it.
http://download.yamaha.com/search/result/?site=usa.yamaha.com&language=en&search=HTR-5930
Sep 24, 2014 | Yamaha HTR 5930 - AV receiver - 5.1...
I have a Yamaha HTR 5960 receiver hooked up to a Klipsch 10" synergy sub. The system has been set up for about 6 years and the sub suddenly quit working. I have checked connections and the sub is getting...
If you remove the signal cable from the amplifier while the Sub is switched on (turned down about half way) you should hear a thump sound. If you do that proves that your sub is working and you need to look at your Yamaha. Perhaps the sub channel has been disabled in the logic settings. Check the speaker configuration pages. If all looks well reset your amp to factory settings and try again. I have had a logic glitch which was fixed in this way.
Nov 23, 2013 | Audio Players & Recorders
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
How do i connect headphones to htr-5960
Does it have a headphone jack on the front of the (Reciever)
Dec 05, 2012 | Yamaha HTR-5960 Receiver
Yamaha 5960
Does your reciever use a remote control?
If so, you should be aware that on many recievers and surround amplifiers some of the functions may only be accessible via the remote control (the best way to learn about it is to consult the user manual).
I have a Pioneer VSA-730 surround amplifier and the only way i can change the mix levels for surround/sub/center speakers is by a remote control. My friend had the same problem and, after reading the manual, he discovered that he actually needs to use the remote control to access all functions of the amplifier.
Good luck and best regards
3rq8 (Triarcuate)
Jul 15, 2009 | Yamaha HTR-5960 Receiver
I have a Yamaha HTR-6130 connected to a Samsung 550 plasma tv. I find the speaking sound in movies and tv programing to be too low relative to other background sounds. Any way to raise the relative...
If your running the receiver in 5.1 using a center channel, go into the main menu of the receiver and select "speaker settings" toggle to "center channel" and adjust the gain to taste. If you need more help, post a comment and I can help you some more
Jun 25, 2009 | Yamaha HTR-6130 Receiver
No dolby digical in DVD mode.
PCM mode will not output dobly digital, use the digital cable connection, not RCA cables, set DVD audio output menu to Dolby digital or DTS. On DVD software menu setup select audio then Dolby Digital 5.1 or Dolby Surround.
Jan 25, 2009 | Yamaha HTR-5960 Receiver
Nov 23, 2008 | Yamaha HTR-6130 Receiver
Jan 06, 2008 | Yamaha HTR-5240 Receiver
Yamaha HTR-5960 Receiver Logo
233 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
