Question about Vivitar ViviCam 5385 Digital Camera
My computer say that> the disk inserted is not readable by this computer>
How to reset forgotten Windows server 2003 password?
With Windows Password Genius, only two steps are needed to reset forgotten Windows server 2003 password.
Step 1: Create a Windows password reset disk on an accessible computer
>> Download full version of Windows Password Genius Raid on the computer you can access.
>> Insert USB or CD/DVD into computer and launch Windows Password Genius Raid
>> Select USB or CD/DVD you have inserted into computer just now and click "Begin burning" to start boot disk burning
>> When "Burning Successfully" message pops up, click "OK" to make sure you have burned a Windows password reset boot disk.
Step 2: Reset Windows server 2003 password on locked server
>> Insert Windows password reset boot disk into locked server, and click "Del" or "F2" to boot it from USB or CD/DVD when the server starts.
>> Until Windows password recovery program interface appears, affirm Windows system and select user account you prepare to recover its password.
>> Click "Reset password" and then dialog box pops up, choose "Yes" to eject Windows password recovery raid and restart server later.
If not, close the dialog box, and click "Reboot" directly to start server immediately.
Aug 09, 2013 | Dell Computers & Internet
Disk for Zip 750 Firewire is not readable
sometimes you get this problem if you have changed software version what software was you using before and are these zip disks off your comp originally or from another sourse you could try reinstalling the software that came with it or if dont have software you should be able to get it off the net hope this is some help ...............................................
Nov 08, 2007 | Iomega (32453) External ZIP Drive
Instal ocr on my computer
The Lexmark OCR scan software is available in the installation disk only. Insert the disk in your computer to install the software. You can also manually install it. Insert the disk in your computer > open My Computer/ Computer> right click on the disk Drive for the Lexmark installer > Explore (XP)/ Open (Windows 7). Open the OCR folder and execute the Setup application. Just finish the installation.
If you don't have the disk or you lost it, feel free to contact Lexmark technical support. Thanks.
Oct 15, 2010 | Lexmark X1270 All-In-One InkJet Printer
Computer shows the pen drive without its name. But when I try to open it gives message 'insert disk in drive F'. I started my computer keeping pen drive attached to it, in tis case, the message is ' format...
connect it to PC then... go to My Computer icon on desk top >> right click >> manage >> Disk management >> select ur USB Flash Drive/pen drive >> right click >>format ....ok......
Sep 01, 2010 | Kingston 4GB Secure Digital High Capacity...
Recovery disc
To create an Acer recovery Disk from the computer follow the below mentioned steps:
Click Start Menu> All Programs> Acer erecovery management> Under it select the option to create Recovery Disk
Aug 02, 2010 | Acer Aspire One PC Notebook
I have a Zip 250 disk that will not read. When I insert the disk in the external disk drive, it will spin and stop a few times and that's it. When I try to access the disk/drive letter via "My Computer",...
If the disk is unreadable this means that the format or the files extensions on it are not readable in the operation system you use..either are damaged or the disk itself is damaged or it wasn't finalized like it should ...If other disks inserted run ok than the disk it is damaged and it is nothing wrong with the drive itself..When it says to insert a disk this means that it is not seeing the disk at all and it sounds like a drive problem ..but if other disks are ok ..than it is just a damaged disk or in a format unreadable ..beware if it a cd unit ..will not read dvd-es..or if it a dvd kind will not read large dvd-es (dual layer) or blue-ray disks..
May 29, 2010 | Iomega ZIP 250 External ZIP Drive
My computer no longer recognized my hard drive
did your computer device manager recognized your external drive? did disk management recognized you external drive? let me know.
Apr 05, 2010 | LaCie (300770) 250 GB Hard Drive
Memory not readable by PSP or Computer. HelP!
Dear Friend,
you have to check the Following
  • Make Sure Your MMC is NOT PASSWORD PROTECTED
  • Your Card Reader properly Connected to PC(Make Sure GOOD in Condition about the Reader)
  • Properly Inserted MMC to READER
  • Change USB port if Still Not Detecting
  • Try another MMC to Reader
  • Reinsert your MMC
  • Reboot your PC
Remove Lock of MMC(Lock might be in Left Side of Your MMC).Still you have Problem Please Change your CARD READER/MMC ...
YOu are done...Solved.....
IS this HelpED you ... Do RaTe mE...
you can Feel Free contact me... Thanks for Using FixYa
Apr 04, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Vivitar ViviCam 5385 Digital Camera Logo
75 people viewed this question
Top Vivitar Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
