Question about Tunturi Exercise & Fitness
I have a tunturi J6 showing Error 15, what is this Please
3 Suggested Answers
  • 33 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Your problem could be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
stevebuck453
  • 4 Answers
Buckmanservices.com solved the E1 code issue only $30 fixed it from online told me what to do
Posted on Jun 13, 2012
What is an error code E5 mean?
Error code 5 means : Required temperature not reached.
Causes/Trubleshooting
Thermoblock has blown - replace thermoblock.
Power electronics is defective - replace the triacs of the power board or the whole power board.
Attention - determine resistance value of the Thermoblock to avoid subsequent errors.
Jul 09, 2013 | Jura Capresso Jura-Capresso J6
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Tunturi T85 data transfer error
Yoy need now lower power board
Dec 29, 2012 | Tunturi T85 Treadmill
Tunturi t7 showing error 20.
Try to RUN the sotware calibration for diagnostics.
This means user is heavy standing in the drive belt.
Causes: drive belt is worn, brusher motor faulty, motor faulty, motor controller board faulty
Remedies: use AC. clamp for drawn currente entering to the treadmill. Repair brusher and motor. Replace motor controller board.
God bless you.
see the block diagram
Oct 11, 2012 | Tunturi T70 Treadmill
Xerox 5016 copier error j6
error no.j6 asking how to swallow prablam
Dec 27, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I have a Tunturi j770 treadmill with error code E1. What does this mean please?
May 17, 2010 | Exercise & Fitness
My tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
May 16, 2010 | Exercise & Fitness
Tunturi elliptical cross trainer error e-2
Most E 2 code means communication problem upper and lower boards you will need to check connector. for further info go to http://accellfitnessna.com or Email a.parker@accellfitness.com they will help you they Tunturi Distributor of North America
Apr 02, 2010 | Exercise & Fitness
E10 Fault
Hello E10 = Problems during water filling phase ? washing (Machine tries to fill for 10 min without reaching the level) Checks to do: Is there one of the tree valves that is not working? NO, Verify that tap and hoses are letting the water coming in. (tap open, hoses connected and not kinked) Is the wiring OK? (Measure the 3,8 K Ω of the valve from the cable Main board side: - between J6-1 and J6-5 wash valve; - between J6-2 and J6-4 prewash valve; -between J6-3 and J6-7 hot or bleach valve. if NO Replace the cable. Change the main Board Regards David Marsh
May 17, 2007 | Zanussi FJD1466W Front Load Washer
Exercise & Fitness Logo
192 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
