Question about General Electric GE 7 0 Cu Ft Super Capacity Electric Dryer - DCVH680EJ / DCVH680EJMR - colo
I have a GE DCVH680EJMR dryer and it will not turn on. I set the settings and push start I hear a click but nothing happens. The drum does not turn. I am afraid to leave it on because I had a house fire not to long ago do to my dryer starting on fire.
protek480
  • 1714 Answers
SOURCE: GE Dryer GEW9200LW. Panel works, door is closed
You may have a broken belt that connects the drum to the dryer. Watch this video,
Posted on Jul 20, 2009
localwonder
  • 6784 Answers
SOURCE: Dryer drum will not turn
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch will not activate and the dryer will not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
jumptrout51
  • 3361 Answers
SOURCE: My dryer drum sparks when i push on it
You have loose or shorted wiring in the dryer. Unplug the dryer.Raise the top lid. Remove the screws on the top right and left inside the dryer to remove the front panel. Disconnect the door switch wires and set the panel aside. Reach in under the drum and remove the drive belt from the motor and pulley. Remove the drum. Inspect the wiring visible inside. Remove the rear panel from the dryer and inspect all wiring and thermostats and fuse relays.Remove the terminal cover where the cord connects and inspect all wiring there for broke or loose. Open the control panel and inspect all wires there for broken or loose. Repair any wiring found defective and replace any parts found defective.
Posted on Sep 17, 2009
emissionwiz
  • 76673 Answers
SOURCE: I have a GE Profile
Hello
You need to do some basic testing for me so we can at least get a preliminary idea of the problem here, open the dryer door and spin the drum, does it spin fairly easily? if it doesn't there is a problem that must be addressed first, then I want you to hold the dryer door switch in and spin the dryer drum while a helper pushes the start switch in, if the dryer drum spins and stays running the motor start capacitor or switch on the motor may be defective, if it doesn't start then the dryer motor may be defective, let me know what you find out asap.
Posted on Dec 19, 2010
  • 3074 Answers
SOURCE: i have a GE DCVH680
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Mar 13, 2011
Model DPSB620GC1WW, SET SETTINGS, PUSH START AND DOES NOTHING BUT CLICK
Reach inside and move the "drum" by hand. then close the door and try again. I have seen the exhaust fan so full of lint that the motor can't turn. If you are not comfortable taking the back off then you will need to hire it done
May 17, 2015 | GE Gas Dryer Model Dpsb620gc1ww
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
My LG Tromm dryer makes 3 clicking sounds when I push the start button. Everything lights up as if it is going to work, but when "start" is pushed, I just hear the 3 clicks and then nothing happens
If the drum doesn't turn, check the centrifugal switch on the motor shaft. Check if the belt hasn't broken or if it's off the motor shaft.
Jul 16, 2014 | Dryers
GE dryer turns on but doesn't spin
Probably nothing but a broken belt. Ge dryers can be tricky. Most of them cannot be accessed from the rear anymore. Lots of videos on youtube now that show how to replace a dryer belt on a GE dryer.
Mar 20, 2014 | General Electric GE 7 0 Cu Ft Super...
When pushing the start button the dryer makes a buzz sound but nothing happens. If the belt was broken I should hear the motor running. The dryer is 18 months old and gets normal use for a small family. I...
Most likely the motor. If you have a second set of hands, you can try and hand start it. Open the door, hold in the door switch (or tape it, if you don't have anyone to help), press the start button, and then grab one of the drum fins, and spin the drum counterclockwise and see if it takes off.
Oct 15, 2013 | GE GTDP300EMWS Dryer
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Dryer does not start
CHECK DOOR SW,CHECK DRUM BELT, CHECK THERMAL STAD MIGHT BE OPEN
Aug 20, 2009 | Dryers
Dryer wont come on
check the voltage at the outlet for 220
Feb 16, 2008 | Roper REX4634KQ Electric Dryer
General Electric GE 7 0 Cu Ft Super Capacity Electric Dryer - DCVH680EJ / DCVH680EJMR - colo Logo
97 people viewed this question
Top General Dryers Experts
Tim Whalen
Sal DeAngelo
Are you a General Dryer Expert? Answer questions, earn points and help others
