I have a 55" mitsubichi television. I have had it for about 7-8 years. When I no turn it on, either by hand or remote, it clicks on, the gree lit showing power comes on for a second, but then it clicks off, almost like a circuit breaker going off.
  • 1 more comment
  • jkordowe Sep 24, 2009
    it is the Medallion series (I am not home now to give you more info) does this help?
    I have a 55" mitsubichi television medallion series. I have had it for about 7-8 years. When I turn it on, either by hand or remote, it clicks on, the green lite showing power comes on for a second, but then it clicks off, almost like a circuit breaker going off
  • jkordowe Sep 25, 2009
    how do I locate these boards
    President:
  • 1,462 Answers
HI,
You have to check the following things to ensure that they are good..
There are two PICO fuses in the main board F9A04 and 05, try checking they are fine and if they are worn out try replacing them
Check for any bad capacitors in the DM board, if you find any try replacing them..
Think this should solve your problem, with power issues
If you still need furthur assistance, please leave me comment,we may help you furthur
RNJ VINODKUMAR
Posted on Sep 25, 2009
  • Vinod Kumar
    Vinod Kumar Sep 25, 2009
    Just remove the back panel and you can see power cord being connected to the board, this board is called power board,check this board and you can see all ICs there
  • 10,594 Answers
Sounds TV got problem either in convergence out section or in horizontal deflection section.
Please intimate model number written at back of TV to look into schematics for possible cause of problem and its solution.
Let me know also if you want to fix it by yourself as it requires fair knowledge of electronics and experience.
Thanks.
Posted on Sep 24, 2009
  • Shahid Electronics
    Shahid Electronics Sep 24, 2009
    I'm afraid, it does not help, model number would be written at back of TV and that number will help me to look into schematics of TV to find out info for you.
I have sony 55" wega
If this is just a problem with the remote specifically and 'not' manual buttons (on the tv) then the problem is either the remote or the IR sensor in the TV.
First thing is to check the batteries (which im guessing you have done) but its a process of elimination.
Second is to try another remote. If you can get your hands on another universal remote for example, then you can see if its the IR sensor on the TV, or just the remote control.
Wireshark Cookie Dump:
OKCancel
Mar 06, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I need 4 digit code for Samsung and Mitsubichi tvs
which code? Is it for programing a universal remote? If so, which remote?
Feb 27, 2011 | Televison & Video
Pink and gree circles on tv
no there will be apart called as ptc,
it may be gone or having loose contact ,,,its dosent cost much
Jul 19, 2010 | Televison & Video
I have a VIZIO P50HDTV1QA DLP television and it
It sounds like the Color Wheel assembly has gone bad.Call a good TV Tech and explain the symptoms and he should be able to give you a ballpark estimate ($325)
Jul 29, 2009 | Televison & Video
New Samsung LCD TV won't turn on or off
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires. Vitally
Mar 08, 2009 | Samsung LA55A950 55 in. LCD TV
TV won't come on
unplug it for 10 minutes then turn it on at the console(not the remore) and hold the power button in for 15 seconds. this resets most apex tv's
Oct 06, 2008 | Apex Digital GB55HD09W 55" Rear Projection...
Just plain dead
unplug keybord and try to turn on with remote.
Sep 23, 2007 | Mitsubishi WS-55805 55" Rear Projection...
First looked concave Now its dead
call a tech to repair you tv it is having problem in the power supply or related circuit.good luck.
Apr 13, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
