Question about Chaparral Technologies CHAPARRAL - JFS224
Where is the fuse box for a 1998 Chaparral Boat 205LE
I have a 1998 sea ray boat trim will not work
Take 12 volt test light to back of switch to see if its hot. Other guess fuse corrosion and fuse holder corrosion. there maybe 2 fuses. 1 "inline" to trim switch other fuse panel.
Jun 17, 2017 | Boating
How can i figure out what is causing the fuse to blow on the storage compartment lights of our Chaparral 325MKS
With electrical it is a matter of spending the time eliminating the variables. If a fuse is blowing you are more than likely dealing with a short to ground. It could be a staple through a wire or a place in the wire where the sheathing has rubbed through allowing the hot wire to contact a ground source. It could also be a bad ground which is allowing resistance to build and ultimately blowing a fuse. First, determine everything that is on the circuit (which lights). Second, inspect every inch of the circuit for bad connections, loose grounds, and damaged wires. If nothing is found then start eliminating one fixture at a time to see if you can find the culprit. If you disconnect the last light in the series and the fuse still blows. Reconnect the last light and move on to the next light and so on until you find the problem. It can be time consuming and unfortunately there typically aren't any wiring schematics for RV's.
Jul 01, 2014 | Coachmen 2013 Chaparral Mid Profile 325MKS
Troubleshooting bass tracker boat
kill switch possibly problem.
Jun 26, 2013 | Boating
I have a Mitsubishi 2004 3.2 DI and the window front window wipers stopped working after I pluged in a rear light board for my boat, I think the fuse my have blown. Can you tell me what afuse it is an
Use the vehicle manual to locate your fuse box, then refer to the lid on the fuse box for fuse identification.
If all else fails, check each fuse individually.
Nov 04, 2012 | Cars & Trucks
1998 oldsmobile bravada fuse box diagram
On this website you find fuse box diagram and description for Oldsmobile Bravada (1998)
Oldsmobile Bravada 1998 fuse box diagram Auto Genius
Nov 22, 2011 | 1998 Oldsmobile Bravada
I have a Kenwood KDC-MP2032 installed in a boat. I changed the battery in the boat and now I can't get the tuner to power on. If I need to replace a fuse, where are they and what size fuse do I...
Try to check first the fuse on the fuse box of your boat if it is still good then the fuse of your stereo is located at the back of the stereo itself. Detached the stereo from its housing or holder you will see the fuse at the back of it.
Jun 28, 2011 | Kenwood KDC-MP2032 CD Player
My stihl weed eater will start but not rev up
little cable with toggle on the end of it, this has come off the carb
Apr 29, 2010 | Chaparral Technologies CHAPARRAL - JFS224
There is a clacking noise coming from the rear of the boat. It is a Chaparral with a 260hp Alpha drive. It started suddenly and seems to be getting worse each time we drive the boat. Engine runs good and...
With boat on trailer put drive in gear,engine off,remove bellow cover on the lower unit and check u-joint for any slack or noise when you try to rotate prop.Does clacking happen more when you raise lower unit?
Nov 15, 2009 | Boating
Can't get any of my boat trailer lights working on 01 Tundra!
Probably one or more (fuse(s) ) under hood in power distribution box.
Jun 02, 2009 | 2007 Toyota Tacoma
Computers & Internet Logo
273 people viewed this question
Top Chaparral Technologies Computers & Internet Experts
David Payne
David Payne
Are you a Chaparral Technologies Computer and Internet Expert? Answer questions, earn points and help others
