Question about HHP ImageTeam 3800LT (3800ltp-12) Handheld
Imageteam 3800 scanner
I was trying to get the PS2 cable connector on a 3800 scanner off, couldn't and unscrewed the head and the ribbon connector came loose. Can I re-attach it? Where exactly?
Richard@NYCConsulting.com
  • 4 Answers
For future reference, the cable is easily detached by inserting the straight end of a paper clip into the pinhole at the bottom of the handle where the cable attaches.
I would not recommend attempting to repair this device yourself. You could cause more damage than you already have. Since the device has a 5 year warranty, it may still be under warranty. The charge for reconnecting everything, if there is no damage, should be minimal.
Posted on Mar 06, 2008
Couldn't get PM power status MC9090
Mc9090 does not have a battery door?! You should try a reflash by SD card or Activesync, you will need access to support.symbol.com and possibly a service contract to access the firmware.
Dec 06, 2012 | Zebra Symbol Technologies MC909X-G Series...
My HP photosmart printer 2575 will not scan. I get a "no scan options", refer to device documentation to troubleshoot" message. How can I fix this problem?
It seems that you have the wrong drivers installed for the printer or they are corrupted. The best thing to do is uninstall and reinstall the printer. You can reinstall it either from the cd that came with the printer or you can download the drivers from HP's website.
Mar 04, 2011 | HP Photosmart 2575 All-In-One Printer,...
Need an adapter that changes a connection from PS2 to USB.
p/n 42206202-03e is the usb retail lenght, but there are other options
Kim Ganoe 800.933.2839 x251
www.datexcorp.com
Mar 17, 2010 | HHP ImageTeam 3800LR-12 Handheld Barcode...
HHP 3800 barcode scanner won't scan/read - I think
Ok I have found some info here what you need to do is download the correct driver from this site, install and you should be fine. HHP 3800r? is that the right one? http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=165
This one below is for the HHP 3800r ?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=140
Feb 07, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
How to make the imageteam 3800 Scanner handsfree?
YES! In your manual find the programming tag that says Automatic Trigger.
Hope this helps dude!
Feb 10, 2009 | HHP Imageteam 3800 Handheld
I was trying to clean my PS2
Here is a video i made to help you
Nov 27, 2007 | Sony PlayStation 2 (PS2) Console
Error message: Check scanner unit E01-31
there are 2 ribbon cable that connects to the scanner lamp. The one closer to the front is the grounding cable. It connects to the metal plate by a ss plate. You can try fold a piece to fit between the ss plate and the ribbon cable to provide more pressure for the ribbon to the metal plate.
To access the ribbon, you need to take the ADF off by opening the document feeder cover, there is one screw that holds the ADF cover, unscrew that, and pil open the cover, then take the connector off, and then put up the document feeder, there is a lock in the back that u need to use a small screw drive to poke it to take the ADF off. Once the ADF is off, you can unscrew the 2 screws that holds the control panel, then disconnect the connector, then you can unscrew the screws around the glass and u can work on it.
Nov 01, 2007 | Panasonic DP190 All-In-One Laser Printer
PS2 power ribbon Help!!!!!!
Use a pair of needle nose pliers and grip the connection end of the Ribbon cable by the hard plastic piece.  Insert this cable in the second connector from the front.  The connectors are located under the right edge of the CD drive.
Oct 31, 2007 | Sony PlayStation 2 (PS2) Console
Scanning barcodes with colored background
unfortunately it appears that you do not have sufficient Contrast for your barcodes, this will make scanning them difficult, that with the added issues of wear & fading makes the use of barcoded passcards difficult. it's probably better to use RFID or Magstripe cards for this application
Sep 05, 2007 | HHP Imageteam 3800 Handheld
HHP ImageTeam 3800LT (3800ltp-12) Handheld Logo
105 people viewed this question
Top HHP Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
