I just purchased a Steward Audio CVA 50-1 amplifier and four Enforcer Sound E86CW in-ceiling speakers for my son's recently enlarged (62'x32')classroom which currently has a 2-speaker (front of class)soundfield system. Unfortunately,I did not receive any wiring diagrams to show proper connections for various scenarios. The manual included in the shipment keeps referring to the another manual I don't have re- input source for additional information. I cannot find any information about the best location of the speakers for this size of a room nor whether the additional amplifier should be connected to the 25 v or 70 volt pins. As well, the speakers appear to have multiple wires to accommodate either 25 v or 70 volt hookups at various wattages, ranging from .125 t 5 watts respectively. Also, the manual provided refers to Female XLR and Male TRS, RCA and TS connectors which should be added to either the balanced or the unbalanced system without any explanation of what this means and which hookup would normally provide the best results. Any clarification re-the above would be much appreciated. Sincerely, G.W. Gedies
  • gsigroup Sep 24, 2009
    Thank you for your quick reply.
    In response to your questions, following is a description of the controls located at the rear of the StewartAudio CVA 50-1 amplifier as viewed from left to right:
    - INPUT: 3 pins (left to right) +(pos), - (neg), downward arrow
    - RVC: 4 pins (left to right) 10v , RVC, GND, MUTE
    - two pins for power (no problem)
    - SPEAKER: 3 pins: 25V, downward arrow, 70V
    Am I correct in assuming that the speaker transformer wires, that is, the C-BLK (common black??) should be connected in parallel at 70 volts, as you had suggested, but at which of the following wattage values. i.e., 125, .31, .62, 1.25, or 2.5 watts (there is no wire opposite the 70v- 5watt label)
    Could you also please comment on the balanced vs unbalanced system hookup (which is the better?) and the respective connectors apparently required for either system.
    Thanks, G.W. Gedies
  • 4,234 Answers
What you purchased was a distribution amp that usually is used with 70V lines. Each speaker should have a transformer for different wattage levels as you stated. The idea of this type of distribution system is to give you an even level of sound without requiring high volume levels at certain points. Place the speakers where you will get as even a coverage as possible assuming that all speakers are at the same volume level.
Since I don't know your specific model, I can't describe the actual connections. Can you post either pictures or a description of the input and output selections that you have and I'll describe the typical hookup.
Thanks,
Dan
Posted on Sep 24, 2009
  • ABRsvcs Sep 24, 2009
    The balances vs. unbalanced is like using a microphone (XLR type connector) vs. RCA jacks. What are you going to use for the sound source? CD player or maybe the output from a mixer?
    All of the speakers should be hooked up on parallel to the 70V line. The nice part about it is that you connect then as follows:
    Amp ==> speaker ==> speaker ==> speaker ==> speaker
    Using the 70V system makes the connections of multiple speakers trivial. You can always add more if needed. Just keep adding them onto the end in parallel (black-black and red-red).
    The amp should have a power rating of x Watts. Set the speakers to what ever makes sense, but be consistant. I would set each one to 1/2 W to start. Connect them to the arrow and the 70V. The arrow should be ground.
    Dan
How do i choose surround sound speakers to go in my ceiling?
Go to any store that sells electronics and audio products, they will be able to guide you towards the correct speaker purchase for you needs.
Dec 01, 2016 | Audio Players & Recorders
I have a 2009 GMC Yukon and rear speakers aren't playing
Does the system have an amplifier ?
Circuit/System Verification
Radio ON, Rear Seat Audio (RSA) OFF (if equipped), adjust the fade and balance controls on the radio to test all four channels individually. Each of the four channels should produce clear and even sound.
Without Amplifier Radio ON, verify clear audio is heard from each audio speaker.
If audio is inoperative from all speakers, replace the radio.
If audio is inoperative from one or more, but not all, speakers or the audio emitted from the speakers is not clear, refer to Speaker Circuit Malfunction - without Amplifier.
With Amplifier Radio ON, verify clear audio is heard from each audio speaker.
If audio is inoperative from all speakers, refer to Amplifier Circuit Malfunction.
If audio is inoperative from one or more, but not all, speakers or the audio emitted from the speakers is not clear, refer to Speaker Circuit Malfunction - with Amplifier.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the appropriate speaker.
  2. Radio ON, test for 5.0-7.5 volts between the signal circuit terminal A and ground.
  3. ?‡'
    If greater than the specified range, test the signal circuit for a short to voltage. If the circuit tests normal, replace the radio.
    If less than the specified range, test the signal circuit for a short to ground or an open/high resistance. If the circuit tests normal, replace the radio.
  4. Test for 5.0-7.5 volts between the signal circuit terminal B and ground.
  5. ?‡'
  6. If all circuits test normal, replace the speaker.
Apr 17, 2016 | GMC Cars & Trucks
Want to add external speakers that are mounted in my ceiling. They are a good quality household speakers
How do I Connect Multiple Speakers to my HiFi Amplifier
geoffthegreygeek.com/connecting-multiple-speakers-to-amplifier/
Understand connecting multiple speakers to your hifi. ... In a home theatre amplifier with surround sound, there may be 5, 6, 9 or 11 amplifiers ..... Two 4 ohms speakers in parallel totals 2 ohms, not good for an amp designed for 4 ohms or more. .... I have 6mounted ceiling speakers and I want the same sound on all of them.
Home Audio Installation: Install a Whole-House Audio System
www.familyhandyman.com > Skills > Electrical
New high-tech components make it easier than ever to install your own ... what to buy and show you how to run the wires and mount the speakers and controls. The rest is simple plug-in hookups. ... Run wire and install speakers and distribution modules so that you can .... Put it right next to the audio equipment if you want.
In-wall and ceiling speakers buying guide - Crutchfield
www.crutchfield.com/.../home/speakers_inwall.h...
Crutchfield CorporationHome Speakers / ... In-wall and in-ceiling speakers have become some of our best-selling ... about audio quality, and are also a great solution for folks who don't want to... But instead of being attached to a cabinet, it's mounted in a frame and set ...They're a great way to add background music to small or awkward spaces, ...
Dec 28, 2015 | Audio Players & Recorders
No sound from deck
Are the speakers connected directly to the JVC? If so, all four speakers going quiet could be bad soldering on the radio. If the speakers are not connected to the radio, then check the blue/white wire that turns on the internal amplifier.
Aug 06, 2013 | JVC KD-G340 Car CD/ MP3 Player
Where do I find speakers for my NEC plasmasync 50MP1? The unit our CEO has does not have on-board speakers, but utilizied ceiling mounted speakers. It was recently moved to a new site and the speakers were...
This monitor has onboard amplifiers and external speaker terminals which can be connected to any set of speakers. The amp puts out about 7W per channel. There are attachable speakers made for this monitor (model PX-50XM1U-S1) which you may find as well.
Hope this helps,
Dan
Apr 30, 2010 | NEC PlasmaSync 50MP1 50 in. Television
No sound coming from JVC FS-SD7
You burn out the audio amplifier IC you need to replace him
Mar 28, 2009 | JVC FS-SD7 CD Shelf System
Soundstorm amp
Your D-SERIES amplifier was designed to operate efficiently at loads down to 2 Ohms.
This means that you can install four 8 Ohm speakers per channel when using parallel wiring.
of an additional 10W to each speaker.
Please note: The gain control of any car audio amplifier should not be mistaken for a volume
control. It is a sophisticated device, designed to match the output level of your audio source unit to
the input level of the amplifier . Do not adjust this input level to maximum unless your input level
requires it. Ignoring these instructions will result in an input overload to the amplifier, and excessive
2 Ohm Operation
front panel will be illuminated, indicating the amplifier has gone into a self-preservation mode.
these conditions before attempting to power up the amplifier again.
When operating at 2 Ohms, the amplifiers will increase their output power by approximately 50%. The
current draw will so increase by about the same amount, also be sure you have enough current to
run the amplifiers into a 2 Ohm load. If you lack adequate current, your music reproduction will be
distorted.
Increasing the number of woofers per channel at low frequencies (up to 100MHz) produces an acoustic
coupling effect. This acoustic coupling increases your power output by 3 dB per speaker, or the equivalent
audio distortion. It can also cause the protection circuit to engage.
Jan 07, 2009 | Soundstorm Force F2800 Car Audio Amplifier
Speaker distortion on high end
Sounds like classic dry joint on speaker terminal ROTELS are well known for it,if you can use a soldering iron or know someone who can resolder the pins where these terminals are connected,always make sure amp is unplugged from wall socket before ...
Dec 18, 2008 | Onkyo M-282 2-Channel Amplifier
Converting 2 channel amplifier to 2.1 amplifier
it is not availlable to do such convertion.
Jul 05, 2008 | Audio Players & Recorders
Sound
i think the Tv is Normal working. No need to replace the TV. the problem only in your audio processing circuits. Audio driving unit or Audio power amplifier IC might be faulty. You can replace this IC and get the real sound back. To do that contact authorised service personnel. all the best
Dec 22, 2007 | Philips 32PT6441/37 32" TV
35 people viewed this question
 Grubhead
Grubhead
