FixYa.com
Tags:
Toshiba Satellite  A135-S4527 PC Notebook
Toshiba Satellite A135-S4527 RAM Cover (by 2 users)
posted by EVulture on Dec 16, 2007
How does one go about getting this cover off without breaking it? Once the screw is removed, there seems to be two latches holding it down internally.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by dave2579, posted on Mar 20, 2008
Cannot get the Memory Module Slot Cover off the back of my A135-S7404. Can loosen the screw and lift the cover a little, but it doesn't seem to want to come off. Any clues would be appreciated. . .
Solution #1
posted on Jun 15, 2008
Not Rated (0)
samisam
Rank:Wiz Wiz
Rating: 81%, 44 votes
The cover will come off. It need a little minor force from both sides since it has tabs causing the cover to remain somewhat secured. try a flat "plastic" head.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Dec 22, 2007
Not Rated (0)
r0chelle
Rank:Master Master
Rating: 82%, 18 votes
Here you can find some very good bit by bit instructions
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
hope this helps and please vote. thanks
Can you Help with these PC Laptops problems?
Cursor freeze and symbols from...
The cursor will freeze while... Answer This...
Power up question
Recently my adapter for... Answer This...
Blue screen Freeze!
Thanks for trying. I appreciate... Answer This...
no cd with headset
you mean that came with... Answer This...
Still doesn/t work......any... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
