Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Craftsman Pressure washer will not spray
I have a craftsman pressure washer 2200 PSI. It starts ok and runs fine but no water comes out. Hose is connected, water running from house, just does not come out of the nozzle. What am i missing?
  • 691 Answers
Your not missing anything, check the pump, they tend to go bad over time and may need replacing. The pump provides the pressure as well as the suction for the whole process, pulling water from the hose or tank and pushing it forcefully through the pressure washer line. If the motor is running and you have the water going through the line and to the pump, and no water is coming out, my guess would be the pump.
Posted on Sep 24, 2009
Water leaks at base of high pressure spray hose. How can I remove the hose?
Slip joint pliers work well, check screen when removed. Vise grips may be required to remove hose connection.
Apr 20, 2016 | Craftsman 1700 PSI, 1.3 GPM Electric...
Engine runs fine. But it quits when I pull the trigger on the wand to start washing
Does this behavior change if the engine is warm and on minimum choke? Do you get any water spray before the engine quits? Carburetor could be dirty or float stuck. Try putting dose of carburetor cleaner through engine and cycle choke lever and engine speed lever back and forth while engine is running after it has warmed up without running water spray. See owners manual.
Apr 03, 2015 | Craftsman 2700 PSI,2.3 GPM Briggs &...
Water hose won't come off pressure washer
release pressure by squeezing trigger then grab the brass quick connect fitting at the knurled section (at end of hose) and push it toward the pump. when properly pushed back, the hose connector will pop out.
Aug 11, 2014 | Craftsman 2700 PSI Briggs Stratton...
After the winter my motor runs fine but no water pressure
Did you drain the pump in the fall? Cracked housing or blown gasket.
Apr 22, 2014 | Garden
I have a craftsman 675 pressure washer. It runs fine. But when I turn on the water, it dies. What is wrong with it?
either the engine is worn and has no power or the pump is overloading the engine........
squeeze the trigger before you turn on the water.....
try no high pressure hose to make sure the water exits the pump ok
Sep 01, 2013 | Craftsman Garden
I bought a new 2600 psi pressure washer. It starts great. The pressure starts out fine. However, when I disengage the spray nozzle lever and then push it again there is along delay before I get any...
Hi. I think the problem may be called either vapor lock or cavitation, or it could be called something else, but the solution is to take the wand apart in the center and let the trapped water escape, then putting it back together before re-engaging the lever.
Sep 14, 2011 | Craftsman 2600 PSI Honda Powered Pressure...
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Jun 23, 2009 | Karcher 2500 PSI Pressure Washer
No pressure to handle
sounds as if pressure relief valve is stuck open. you will have to disassemble relief valve and clean or replace.
Jun 22, 2008 | Karcher 2500 PSI Pressure Washer
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
1,281 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
