Question about American Standard 2860.334 Enfield Two Piece Toilet
Flush doesn't work - when i press the handle the water does not rush into the bowl. the tank just refills
  • 54 Answers
Replace the flapper
Posted on Sep 26, 2009
What causes a loud gurgle after flush?
If the flapper does not seat correctly and completely, refill water flows into the bowl and causes a "false flush" and the loud gurgle. You can demonstrate this by holding the flush handle depressed after a normal flush. Also, there may not be sufficient slack in the flapper chain to allow it to seat correctly.
If the flush valves were installed exactly according to the instructions, they should work perfectly and can be excluded as a source of the problem.
Jan 23, 2016 | Home
When flushing, only a small amount of water leaves the tank, and the bowl just empties. The chain has a little slack to close, however, it does not hesitate at all. When flushing, the chain lifts the...
Try holding the handle down until the tank empties completely. If the tank leaks into the bowl during or after refill, the flapper is defective and not sealing correctly.
Jun 21, 2017 | Kohler Memoirs toilet tank with Stately...
My toilet is a duravit 1930 series model with Euro style push flusher rather than handle. Internal flushing mechanism is not traditional float ball. toilet water constantly leaks from tank into bowl...
A fairly easy ( but messy ) fix - get a replacement tank to bowl gasket and bolt kit, shut off water supply, drain tank, remove bolts ( you might have to cut, depending on your water source and minerals in your water). Remove old gasket and clean surface with 00 grade steel wool. Replace gasket, install new bolts, remount tank.
Good luck!!
Nov 17, 2010 | Duravit Tribeca US-Type Elongated Toilet...
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Jan 23, 2010 | Toto Aquia II Dual Flush Toilet
G-max flushing system is not filling to proper level
Is it not refilling the tank or the bowl? I've got a toto also that is not fully refilling the bowl after each flush. No leaks or other problems. Tank refills fine. Seems that the flapper doesn't float long enough to allow a sufficient amount of water to drain into the bowl before closing. Any ideas?
Jan 06, 2010 | Toto Drake ADA Compliant Toilet with...
Tank not holding fill level...
Most likely, you do not have a good seal on the flapper valve at the bottom of the tank. To confirm, try this:
Turn off water and flush toilet. Then lift up the flapper valve and put a light coating of vaseline on the mating surface where it contacts the toilet tank when closed.
Turn water back on and see if it continues misbehaving. If that fixes it, it was a bad seal. Usually that is all it takes.
Dec 15, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Bowl will not fill.
There is usually a small tube on the top of the ballcock or the fill valve in the toilet tank. The tube should be clipped to the top of the flush valve pipe so that the water will flow into it. Should the small tube become loose and fall off of the clip, the refill water will not make it back into the bowl.
Aug 09, 2009 | Home
In the tank, when I flush, water comes shooting out of the black plastic thing, about 2 feet high! How can I make this stop so it flushes properly again? (its an eljer 2001)
is the black thing between the the tank and the bowl?
if so, go to any of the home center or plumping store for the seal.
shunt off the water and unbolt the 3 bolts that holds the tank to the bowl from the buttom. you may need a flat screw driver to help hold the bolts. pull up the tank slowly, and lay it on the side, replace the seal, reseat the tank on to the bowl and tighten the bolts. make sure all bolts are equal pressure and the tank is level.
May 05, 2009 | Eljer & Patriot& Elongated Toilet Bowl
After flushing, water does not refill the tank.
yeah sounds as though the ball valve or water inlet valve is stuck in the closed position or jammed so when you flush the loo the water doesnt refill.
Isolate water service remove valve as required clean/replace re instate test & leave working
Dec 15, 2008 | Toto Carlyle 1-piece Elongated Bowl Toilet
American Standard 2860.334 Enfield Two Piece Toilet Logo
32 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
