Question about Brother MFC 210C All-In-One InkJet Printer
Ink cartridge (not) installed properly
Whenever i try to print, an error message pops up saying that an ink cartridge is not installed properly. I've taken them out and put them back in numerous times, and nothing seems to be working. I know they are the right cartridges and that they are properly installed. But the printer refuses to print. Machine has n error message stating: Install yellow cartridge". I have uninstalled and reinstalled it several times to no avail. Please Help!!!
  • wlmlaw Dec 17, 2007
    My Brother MFC-210C has the same refer to troubleshooting and
    routine maintenace message. I don't understand the 8 0
    instruction. Could you do that step by step. No reference in
    User's Guide to this at all.
  • Anonymous Dec 20, 2007
    i have same problem as above. please help me
  • 832 Answers
Unplug machine from power outlet. take all carts out. wait 5 min. plug machine to power. wait until machine demands carts. reinsert carts and make sure they are secured. answer display when asked if you have changed.
If you still have the error message use a original brother cart.
Posted on Dec 16, 2007
  • Mix-it-up
    Mix-it-up Dec 18, 2007
    @wlmlaw:
    Could be plz give some more details what is wrong with your mfc?
    Does the machine display some kind of error EXCEPT the mentioned one in the 1# post (no ink cart)?
    If yes, you should press menu then start bk copy then fourtimes arrow-up to get to the maintenance mode. machine will display an error no code. plz post as a NEW post here.
  • Mix-it-up
    Mix-it-up Dec 20, 2007
    Have a look into the cart holder. Is the position of the led contacts which give info about the ink level in a good position? If yes, like shown in the pic, the led is defective: The cart holder needs replacement.
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
Hello I have a Lexmark X4650 printer. I was printing earlier this morning and then suddenly, the printer stopped working and gave the error message that left cartridge is incorrect (I haven't...
Good job in re-seating the cartridges into the printer. Try to insert a different known working cartridge to determine if your other cartridge has gone bad.
Jul 24, 2011 | Lexmark X4650 InkJet Printer
I just inserted a black PG 40 ink cart and theres an error coed 5 indicating that i need to insert a color cart. i set my ink stat to black only and gray scale and it still wont pint
I think you need to have both cartridges in your printer in order to print. If you have put the PG-40 only, the printer can't connect the electric circuit and won't work. Canon's manual explains the error code: the ink cartridges are not installed, or a non supported ink cartridge is installed or the ink cartridges are not installed properly.
So, my guess is either to pop in a Cl-41 and print or, if both cartridges are in, remove them from the printer and gently clean the electric circuit on them with a dry cloth. You can also clean the cartridge carrier. Put the cartridges back in and try printing. If that doesn't work, try holding the "resume" button (triangle in circle) for about 10 sec for each cartridge, that should reset them.
Hope that will help solve your problem!
Apr 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Sep 16, 2009 | HP Officejet 7210 All-In-One InkJet...
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer says ink cartridge not recognized.
Take the black ink cartridge back to the person who refilled it. The Microchip that's on the cartridge was not reset properly that's why the printer is returning that error.
You can try some steps before you take it to them to verify it.
1: reseat (take out and put back in) the cartridges into place
2: buy another black cartridge just to check if it will be recognized by the printer, if it does recognize it we know the cartridge is defective. If a new cartridge is also not recognize, start to check your warranty option with the manufacturer...
Sep 05, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
Did you make sure that the colored tape was removed from the back of the ink cartridges? The manufacture puts the tape on there to protect the circuits during shipping. If the tape is still there it would not be able to communicate with the printer or computer.
Sep 19, 2007 | Canon PIXMA iP1600 Printer
Brother MFC 210C All-In-One InkJet Printer Logo
316 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
