Question about Cell Phones
I can not get an outside line or receive incoming calls. A caller just hears ringing but it does not ring in the office
  • 72 Answers
Actually the profile you are using during the office hours is set in such a way thatall the incoming calls are silient when that profile is switched on. So just go to profiles and change the settings of that particular profile as per your requirements. your phone will act in the same way as you set.
Thanks
With regards
Lakshay
Posted on Sep 25, 2009
When a call comes in and I transfer to my boss' extension, incoming calls do not come through, caller states phone keeps on ringing. Also on that same extension calls do not transfer to voice mail.
  • Begin the transfer. With the caller on the line, press the "Transfer" key. The caller will automatically be placed on hold and you will hear a dial tone.
  • Connect the caller to the other party. Dial the extension of the party you wish to reach. When you hear the extension ring or after you've announced the caller, complete the transfer by pressing "Transfer" a second time. If the person does not wish to receive the call, press "Release" to disconnect from the dialed extension. Press the key beside the flashing arrow on the LCD indicator where the various lines are displayed to return to the caller.
  • Cancel an incomplete transfer. If you make an error when dialing and need to retrieve the caller, simply press the key beside the flashing arrow on the LCD indicator.
  • Park an incoming call. Parking a call at a designated extension allows the recipient to answer the call from any phone in the facility. With the caller on the line, press the "Park" key twice. If your system designates a particular extension for parked calls, the caller will be held at that extension. Otherwise, the caller is held at your extension. To specify an extension for a parked call, press "Park," dial the desired extension and press "Park" a second time. Replace the handset.
  • Retrieve a parked call. On any system phone, press "Park" and dial the extension on which the call is parked. You will be connected to the caller.
Aug 18, 2016 | Nortel Norstar M7310 Telephone
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
Oct 03, 2017 | Uniden DECT 6.0 Cordless Telephone...
How do I use use a distinctive ring to separate the incoming fax from the incoming normal calls I want to direct to the answering machine. I am from S. Africa. I am using an all in one Samsung SCX-4521F. I...
Firstly, you will need to get a 2nd ringtone from your phone provider. Most of them will provide a designated "fax ring" (not a new number) for little or no cost.
In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. “Distinctive Ring” is a telephone company service which enables a user to use a single telephone line to answer several different services.
Using the Distinctive Ring Pattern Detection feature, your fax machine can “learn” the ring pattern you designate to be answered by the fax machine. Unless you change it, this ringing pattern will continue to be recognized and answered as a fax call, and all other ringing patterns will be forwarded to the
extension telephone or answering machine plugged into the EXT. jack. You can easily suspend or change Distinctive Ring
Pattern Detection at any time.
Before using the Distinctive Ring Pattern Detection option, Distinctive Ring service must be installed on your telephone line by the telephone company. To set up Distinctive Ring Pattern Detection, you will need access to another telephone or someone available to dial your fax number from outside (a cell phone will do!).
To set up the DRPD mode:
1 Press Menu until “Fax Setup” appears on the top line of the display.
2 Press the scroll button ( or ) until you see “Receive Mode” on the bottom line and press Enter.
3 Press the scroll button ( or ) until you see “DRPD Mode” on the bottom line and press Enter.
4 When “Set” displays on the bottom line, press Enter.
“Waiting Ring” appears on the display.
5 Call your fax number from another telephone. It is not necessary to place the call from a fax machine.
6 When your machine begins to ring, do not answer the call.
The machine requires several rings to learn the pattern.
When the machine completes learning, the LCD displays “End DRPD Setup”.
If the DRPD setup fails, “DRPD Ring Error” appears. Press Enter when “DRPD Mode” displays and retry from step 3.
7 To return to Standby mode, press Stop/Clear.
When the DRPD feature is set up, the DRPD option is available in the Receive Mode menu.
To receive faxes in the DRPD mode,
you need to set the menu to DRPD;
NOTES:
• DRPD must be set up again if you re-assign your fax number, or connect the machine to another telephone line.
• After DRPD has been set up, call your fax number again to verify that the machine answers with a fax tone. Then have
a call placed to a different number assigned to that same line to be sure the call is forwarded to the extension telephone or answering machine plugged into the EXT. jack.
• In Tel mode, you can receive a fax by picking up the handset of the extension phone and then pressing the remote receive code Alternatively, you can press On Hook
Dial
(you can hear a fax tone from the remote machine) and then press Start on the control panel of your machine.
• In the Fax mode, the machine answers an
incoming call and immediately goes into fax
reception mode.
• In Ans/Fax mode, the answering machine answers an incoming call, and the caller can leave a message on the answering machine. If the fax machine senses a fax tone on the line, the call automatically switches to Fax mode.
• In DRPD mode, you can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. This option is available only when you set up the DRPD Mode.
The full user manual for your machine is located here
Hope that is of help to you :)
Nov 09, 2009 | Samsung SCX 4521F All-In-One Laser Printer
No ringing sound for second incoming call
On the intercom, if it's a TA or similar phone system, dial 7311# for call waiting on outside lines and 7321# for call waiting on the intercom. (0 cancels).
Carl
May 21, 2009 | Panasonic KX-TS3282W Corded Phone
Can't receive incoming calls
same here... I unlock it but it doesn't received call
Aug 16, 2008 | Motorola Mobility A1200
No ring out when line switched.
It could be that the line that you are connecting to is not the number that you think it is. call someone that has caller id and make sure that is the number you think it is. Do other phones ring when connected to that jack?
Feb 15, 2008 | Lands Phones
Can't hear the Ring
Hello, Push the center button(in the middle of the four directional arrows). Scroll over to the screwdriver/wrench icon and select it. Scroll down to the "Audio" line and select it. Scroll down to "Loud Detail" and select it. Set "Ring Volume" to a higher number(I use 7). Have someone call you and you should be set. If this doesn't work, with the phone open, look at the two buttons on the left side of the phone, push the top button until you have your desired ring volume. Good luck!
Jul 26, 2007 | Motorola Mobility V710
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Cell Phones Logo
60 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
