Question about Garden
My Karcher electric K3.91MR 1700psi pressure washer was foound to be broken and incomplete when I opened the box. Where can I send it to get it repaired?
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
  • 389 Answers
SOURCE: I was using the pressure washer and it stopped
This problem, where the unit continually switches on and off when the handgun is closed, is quite common. Unfortunately it has at least six different possible causes, only two of which are easily checked.
The first thing you can do is look for leaks.  Even the slightest leak will cause this pulsing because the unit gets up to pressure, switches off, loses pressure, switches back on again, comes back up to pressure, switches off... and so on.  This repeated switching is not good for the motor and should not be allowed to continue for longer than necessary to observe what's happening.
So... 1. Does the handgun shut off completely, or does it drip? If it drips, it may simply be because a seal has failed. The handgun can be dismantled, checked, and any defective parts replaced; be sure to lubricate O-rings with silicone grease when reassembling. As a last resort, the whole gun may need to be replaced.
2. Are there any visible leaks at the high-pressure hose screw connections?  If so, most likely an O-ring needs replacing - again lubricate the new one well with silicone grease.
3. If there are no visible leaks, either from the gun or from the connections, all other possible causes are internal within the cylinder head or control head of the pump. New parts will be needed and this normally calls for a professional repair, although it's not beyond the scope of a truly competent amateur.
I hope this helps. Any further questions, just ask! Please remember to rate this response.
Posted on Apr 17, 2009
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare parts...you can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Regards,
Fulltech.
Posted on May 30, 2009
  • 3 Answers
SOURCE: Karcher pressure washer with Honda GC160 engine only runs on chok
You need to remove the carb bowl, then with a small flat screwdriver remove the jet. ( on the side, at the bottom of stem.) take a small wire or toothpick and clean the gunk out of the jet, reassemble and open fuel valve, start, and pat yourself on your back.
Posted on Aug 04, 2009
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
I have a karcher g3200xh .the motor works ,but the pressure water won"t pressure up.
low pressure usually caused by cracked head but more commonly by dirty or broken valve (two per cylinder) remove and inspect each valve for debris or missing orings etc then replace before opening the next, a short cut sometimes is to blow compressed air through the inlet,
Aug 20, 2013 | Campbell Hausfeld 1800 PSI Electric...
How do you reset a karcher pressure washer
The Knob is broken off of the Plastic Shaft..to the switch assembly.
A new switch assembly is available direct from Karcher.
May 24, 2010 | Karcher K2.26 Electric Power Washer
My Karcher (K2.26M) pressure washer is leaking water from the ON/OFF switch and the bottom. Does anyone know what could have broken, and what part I would need to fix it?
I have had a dozen of these units, My advice is not to bother trying to get parts or fix it. Its designed to be a throw away unit!
Oct 31, 2009 | Karcher K2.26 Electric Power Washer
Cycles, never builds up full pressure when trigger pulled
If you are sure it is not a bad o-ring and you have re-assembled it correctly then try this.
Visit here:
http://www.rjbowers.com/parts_manuals/partslist_1190343804.pdf
Part # 8 in the pump, karcher # 9.001-187.0 includes a small bullet shaped valve. It could be leaking. It can be carefully disassembled and cleaned.
Jun 13, 2009 | Karcher K2.26 Electric Power Washer
Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Karcher pistol gun has broken
i do not think there is a pressure release valve , sounds like the plastic inside the pistol has become brittle and has failed under pressure , you dont say how old the pistols are ? and if you run strong detergents through them .
May 26, 2009 | Karcher PSI Electric Pressure Washer
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
Mar 07, 2009 | Karcher K2.26 Electric Power Washer
Garden Logo
97 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
