Question about Ovens
Changing oven elements
Hi, i need to change the oven elements in a philips akg201. i have a new grill element and fan oven element, but im not sure if i can fit them myself. is it a straight forward job. is it possible for you to provide me with fitting instructions? thanks, william shirlow
  • 52 Answers
SOURCE: Indesit grill element not heating up
It may be the oven temperature sensor.
Posted on Mar 25, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    barkencoa
    • 3463 Answers
    SOURCE: cleaning above the grill element
    I would not advise you to remove the element unless you feel competent to do so.
    Best thing to do is to put the grill full on and let all the fat and grease burn itself off.
    you will not hurt anything by doing this.
    Make sure you have the griil door open and your house door.
    Plz rate my solution.
    thanks.
    Posted on Dec 18, 2008
    SOURCE: REMOVAL OF FAN
    Ha - I found the solution myself. You need to remove the 3 screws securing the fan motor. Once you've done this, you can wiggle the fan a few mm, far enough to be able to remove the top element screw.
    Posted on Jan 18, 2009
    • 25 Answers
    SOURCE: Replacement of fan oven element on Nef U1721
    Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
    Posted on Jun 25, 2009
    Smeg oven: UK 80 MFX: Intermittent fault with circular fan element.
    either a bad connection on the element terminals or faulty element
    Jul 10, 2018 | Smeg Ovens
    Fan and element not working
    hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
    open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
    Mar 10, 2014 | Zanussi ZHQ575 Electric Double Oven
    All oven grill and fan elements dead
    The oven will not warm if the clock is not set as the main oven is directly linked to it. You may want to check your wiring to the element you have changed as all elements use the same neutral path, meaning if you missed a wire off (especially if you pulled it out through the oven cavity) or have put them on the wrong tab it won't work. It could also be a duff element (the new one).Let me know if you need any further help.
    Dec 07, 2011 | Neff Ovens
    Hi, It looks as if my heating element on my AKZ446/IX oven has gone, as the fan, oven and grill work fine but no heat come out from the oven. I've seen on the online videos how to change the heating...
    NEmmake sure you removed the correct item first
    replace the oven element, located at the rear of the oven compartment, behind a removeable cover.
    Jan 26, 2011 | Whirlpool AKZ159IX Oven
    Oven problem- grill works but the fan assist wont heat up
    possibility is that the wire that link the oven element and that of grill is loose or burnt
    Sep 25, 2009 | Ovens
    I turn on my Technika electric oven (TB60F) and the fan will run but the oven will not heat. i thought it was the element and was told the element was for the grille, so therfore it has to of been the...
    hi
    behind the panel at back of oven is the fan and around that is a fan element the changes are this will be you problem . just remove panel and check weather the element has burnt out
    regards
    Mar 19, 2009 | Ovens
    Fan oven element
    The test is fairly straight forward: Make sure the unit is off. Generally, there is a screw which holds the element in place near the connector. Remove it and the element will slide out. Now, use a resistance (Ohm) meter and measure the resistance across the terminals. If the unit is visibly damaged or you get no reading (use the 1 K ohm scale), change out the element. If the unit tests good, suspect the control or the wiring from the control to the element.
    Dec 31, 2008 | Ovens
    Fan and grill works but not heating up
    Hi.
    If the fan is working o/k, then you need a new fan oven element fitting.
    Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
    disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
    Plz rate this solution.Thanks
    Dec 24, 2008 | Belling XOU252 Electric Single Oven
    Fan oven not heating, bosch hbn 202t
    the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
    May 04, 2007 | Bosch HBL 5032 Electric Single Oven
    Ovens Logo
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
