Question about Amana Kitchen Ranges
My burners and oven stoped working, I get ignition but no flam
  • Amana Master
  • 5,568 Answers
Although it's very unusual to have a gas line clogged, it is either that or the gas supply has been otherwise interrupted.
If the supply is being lost somewhere, you need to locate where that has occurred since having gas loose in the atmosphere is inviting a serious explosion.
Check with your local utility; if they are supplying gas for your use, they will generally check out your situation with no charge since it can be hazardous for others too.
Posted on Sep 24, 2009
Flam goes on but turns right off
Units for the last 20 years have been using a flame sensor, the sensor is a steel rod that is insulated in ceramic with a single wire located in the burner compartment either with the pilot assembly (if provided) or opposite side of burners from pilot or ignition system which ever it using. The sensor can be removed and cleaned with a piece of sand paper or steel wool then should work OK.
The sensor is a safety device to assure that all the burners are on.
Nov 29, 2011 | Heating & Cooling
Stoves 61gdo main oven not lighting
the thermocoupler is at fault it will need replacing if its stuck on pilot the thermocoupler heats up a small capilary tub that swiches the control to the temp regulator
Nov 23, 2011 | Kitchen Ranges
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Gas dryer flam will burn for about twenty minites
Try cleaning the air intake and exhaust vents for the burner of lint or other debris.
Aug 28, 2009 | Dryers
Oven won't light, even with ignitor getting red
If your oven won't bake, check these:
Bake igniter
Other causes
Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
May 23, 2009 | Magic Chef 9122 Gas Single Oven
Magic chef gas oven range 6498xvs oven no longer works.
i have a magic chef gas range. broiler work, burners work, fan works when you turn the oven on, but oven does not get hot. could it be the electronic ignitor or does even have one.
May 20, 2009 | Ovens
Dacor Preference range oven stoped working
You can try turning the breaker off to the unit for 10 minutes or so but if that does not work you will need a new control board to fix it. they usally range from 100-200 dollars.
Let me know if you have any other questions.
Phil
Apr 10, 2009 | Dacor Preference RSE30SS Electric Kitchen...
Oven & broiler not working
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Jun 28, 2008 | Hotpoint RGB528 Gas Kitchen Range
Please follow this LINK for your manual
Jun 16, 2008 | Hotpoint RGB528 Gas Kitchen Range
Kitchen Ranges Logo
53 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
