Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
New grasshog xp does not feed line, this is the second one i have had with this problem
5 Suggested Answers
  • 313 Answers
SOURCE: My grasshog gh600 wont feed
check out a white plastic lever at the back of the spool line. if its broken then replace it. cost of the parts around $4.00 or so. this parts controls the auto feed of the spool
thanx
Posted on Jun 26, 2008
  • 313 Answers
SOURCE: black and decker grasshog trimmer line feed problem
email publication@bdk.com or see www.dewaltservicenet.com look for the find it now icon & enter the model #
Posted on Jul 28, 2008
  • 3 Answers
SOURCE: My Balck&Decker Grasshog won't automatically feed line.
Just replace the LEVER, Item #29, Part #598435-00, for about $3.00 (B&D, Dewalt). Just pull old level straight out (pliers) and push replacement in. Level end expands to hold it in place. No other parts. Forget cleaning and replacement the spool, graphite or oiling... just replace the lever.
Posted on Aug 14, 2010
woobie dog
  • 1273 Answers
SOURCE: The string on my grasshog xp gh1000 4, feeds out
Hello, W/D here.
Read all the way through this, with the spool in your hand, before you re-wind the spools. It will make much more sense!
Pull the spool off of the trimmer.
Look on the bottom of the spool. The decimal numbers next to the notches on the edge is your line size (e g. .080). If there are 4 notches, there will be different decimal numbers, indicating that your trimmer can take different line sizes.
Also on the bottom will be arrows, indicating the direction that you will need to wind the line.
Looking at the spool, you'll notice that it is actually 2 spools, and the divider between them has a slot in it. (This will be important in a minute). The section of the spool closest to the bump head is the outer spool, and the spool closest to the machine, with the flat side, is the inner spool.
Insert the proper sized line into the hole in the inner spool core about 1/8", and wind in the direction indicated by the arrows, until the line is just about even with the divider between the two spools, then place the line in the notch that is 180 degrees (on the other side of the spool) from the slot in the divider. When the line is in the notch securely, leave about a 6" tail beyond that, and snip the line.
Wind the outer spool in the same manner, but this time, the line will go into the slot in the divider, then into the notch, and also get a 6" tail.
Feed the tails into the grommets in the trimmer head, square them up, notches to grommets, and snap the spool in.
Push the spool in like you were bumping it to the ground (this frees up the advance for the spool).
Grab the two tails, and give a tug. The line will pull out of the notches and advance about 1".
It's a good idea to clean out the hole where tha spool fits onto the trimmer from time to time, and also to put some graphite dust in the hole every 8-10 times you re-wind the spools, just to keep the mechanism working freely.
Best regards, --W/D--
Posted on Feb 09, 2011
Grasshog
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
How to I feed the line in my Black and Decker battery GrassHog weed eater
There are 2 models one has a extendable handle these are both Grasshogs, if i was told incorrectly please contact me. Thank you
12" 18V Cordless Trimmer and Edger MODEL # NST2118 Page 10 http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90559891,NST2118.pdf
18V Cordless Trimmer and Edger MODEL # NST2018 http://servicenet.blackanddecker.com/documents/English/Instruction%20Manual/90509965,NST2018.pdf
Jul 09, 2011 | Black & Decker Garden
The automatic line feeder dosen't work
You can have mine. It wastes line by feeding automatically way too often. Black & Decker sells Junk!
Dec 14, 2009 | Black & Decker 14" Grass Hog Xp...
Aug 24, 2009 | Black & Decker 14" Grass Hog Xp...
The auto feed on the grasshogs don't work
Replace the line with a star-shaped .065" line (I use Rino-Tuff from Home Depot online). I have the GH700 (2 line) model and it fixed the problem for me. Other people have fixed the problem with different shaped lines - apparently there is one at Walmart that works well on electric trimmers. Just don't use the smooth round line. I tried the manual advice and it was bunk.
Jul 13, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Only 1 string trimmer /// string keeps feeding when running
You have the string wound the wrong way on the spool.
Jim
Jun 17, 2009 | Black & Decker 14" Grass Hog Xp...
Black and decker grass hog electric weed eater won't feed string
I bought the electric grasshog trimmer. Worst investment I ever made on Garden supplies. The line is completely gong within ten feet of trimming. I've used it four times and gone through twenty spools. In the trash now.
Apr 22, 2009 | Black & Decker 14" Grass Hog Xp...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Black and decker grasshog
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
190 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
