Question about IBM ThinkPad R40e 2684 Notebook
What do i have to do with the network ,go from enable to connect? Do i need some driver ,and how can i download driver from usb key to hard drive?
  • hansvil Sep 24, 2009
    thank you!
    It is getting close!
  • 15,935 Answers
Insert your Thumb drive and to install the driver off of it - when it asks for the location of the driver - simply pont it to the device listed as a removeable drive.
And yes, opting to connect will get you where you want to go.
Thanks for using FixYa!
Posted on Sep 24, 2009
Samsung gt m5650
Apparently seems like your W-LAN card is either disabled from your network connections or may be there is some hard switch which turned off. All you need to go open network and sharing center then click view network connection to make sure that you Wireless connection is not disabled in any case it should have to be enabled.
Other way is to check on your keyboard from top F1 to F12 keys if you can see a Antenna sign on any of key then press that key by pressing Fn key together.
If the problem still persist then I would recommend you to go on your manufacturer`s website to download the latest driver and update your driver. Good Luck
Oct 01, 2013 | Computers & Internet
Gateway e2610d computer
Check all ethernet ,usb leads and connections for any breaks bends and secure connections
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver or you could download one
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
http://download.cnet.com/2000-20_4.html
on the homepage you will see a search bar type in the ethernet controller freeware you want/need
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html
http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html
i device arrows key scroll to nstalled.
Sep 12, 2013 | Computers & Internet
TP-LINK TL-WN321G - Hi-Speed USB - 802.11g driver not install in window xp
"Enabled"
Apr 03, 2013 | TP-LINK TL-WN321G - Network adapter -...
Having trouble connecting to internet
Wireless or Hard wired ethernet ?
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc You only need to check the BIOS if you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 or you could download one cnetdownload.com on the homepage you will see a search bar type in the ethernet controller freeware you want/need Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC http://download.cnet.com/realtek-rtl8168-8111-pci/3000-2112_4-99235.html http://download.cnet.com/network-drivers/3150-2112_4-0-1-4.html i device arrows key scroll to nstalled.
Feb 27, 2013 | HP Compaq 610 T5870 156 WH248UTABA...
Flashing white light, no connection with ethernet
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device You only need check the following if you cant install the driver Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html if these packages are not the right http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for tick in the box for windows software or all software box IE: Motherboard name Wireless or Ethernet driver you might have to try a few times to get it right
Feb 13, 2013 | Iomega Storcenter Ix2-200 2 Tb Network...
Oblem is i find drivers but than he wants to install and check in the computer what he needs. This is not possible because i can't go on internet with this laptop.
you might have to download the driver to a portable usb drive then install it from there to get an internet connection
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device If you cant install the driver Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html if these packages are not the right http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for tick in the box for windows software or all software box IE: Motherboard name Wireless or Ethernet driver you might have to try a few times to get it right
Jan 31, 2013 | Samsung Computers & Internet
How to go to wifi
Wi-Fi technology enables wireless Internet and network access through public and private hot spots. These hot spots are widely located in homes, restaurants, bookstores, coffee shops and other businesses, so you can keep connected wherever you may travel. To connect to Wi-Fi, you must have an enabled wireless adapter on your computer. Most modern laptops and many desktops have this adapter built into the system, but many lack such capabilities. However, a wireless adapter is easily installed via USB, which allows you to connect to available networks through Windows 7.
Enable your wireless adapter. Most laptops have a hot key labeled with a radio antenna. Hold the "Fn" key and press this key to toggle wireless on or off. Desktops likely have a physical antenna on the back of your computer that is typically always on. If you don't see such a hot key or antenna, you need to acquire a USB wireless adapter. Attach the USB wireless adapter to an available USB port on your computer. Windows 7 will automatically install the necessary drivers for most adapters. If it does not, insert the CD that came with the USB wireless adapter into your drive and choose to install their drivers. Restart your computer if you do not see a wireless icon in your Windows 7 notification area. Click the wireless icon in the Windows 7 notification area and click the network name to which you want to connect. If this is your home network, the correct network will likely be the one with the strongest signal. Click "Connect" and enter the wireless security passphrase, if required. Only secured networks will ask for a passphrase, but some public networks will require browser authentication instead. Open your browser and navigate to any website. If the hot spot requires browser authentication, your website request is redirected to an information page. Follow the instructions on this page to get Wi-Fi. This may entail clicking "Accept," entering a given password or entering a cell phone number. After authentication, attempt your website again to verify accessibility. Hope this helps
b>
Dec 22, 2012 | Computers & Internet
Hard drive went on my laptop. Put in new hard drive and downloading all the disc but can't get the internet to connect wireless or hookup.
Use a computer that is connected to the Internet, download the drivers and copy them to a USB memory stick and then copy them to your laptop and install them from your hard drive or just install them from the USB memory stick.
I suggest you burn these drivers onto a CD so you have these device drives when you need to re-build your hard disk again.
Dec 13, 2010 | Computers & Internet
Compaq presario M2202AP doesnt recognize WD 3200 external usb drive. I cant find the download site for the corresponding usb hard drive. ...
Hi You can download driver from below link. Click here Install driver then check. Also follow below if still not recognize. First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance. Thanks for using FixYa
Oct 13, 2010 | Western Digital Passport 320GB External...
It won't show the green light and show up on the desktop...nothing
First connect it to computer then when you power up the computer press F8 key then enter in safe mode.
Then right click on my computer icon then click on it's property then hardware->device manager.
Then uninstall all usb drivers then restart computer then check .
If still same issue then make sure your computer's usb ports working fine.
Also make sure in bios usb legacy 2.0 is enabled.
For that when you power up the computer press F1 or F2 or "del" key to enter in bios then go to advanced configuration and enable usb legacy 2.0 then save and exit setup then check.
Thanks for using FixYa.
Dec 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
IBM ThinkPad R40e 2684 Notebook Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
