Question about Uniden Cordless Phone
Ge 5.8 25825/26 cordless phone
My handset won't register. Tried following instructions but still no headway. Has lost registration before and I have been able to register but this time it has not registered. please help
SOURCE: handset wont register
Unplug the battery and try again. Worked for me.
Posted on Jun 17, 2007
SOURCE: Cordless GE phone issue. 25825GE3-A
i faced a similar problem.try doing this
1) go to handset menu & somewhere u wil find registration
2)it wil ask for pin , try 5555 or 0000
3)it wil display waiting for reg or searching......
4) press the base station button for some 5 seconds until it beeps continuosly & stops....
5) as beep stops press 1 or 2 or 3 or 4 in handset ( no. of hanset handled by base)...try all possibilities ( sometimes takes automatically if u dont press any number)
6) thats it.......
Posted on Oct 24, 2007
SOURCE: Registering a new phone
I just purchase that same model and I had the same issue as you where the phone on the main station worked and the other 2 sitting on their own base station didn't work. What I did to fix the problem was to put each handsets (one at the time ;-) ) on the main base (the one with the answering machine). The Charge/In use light flashed a couple of time then the handset showed as Ready. I then put each handset on their individual base station and they all work fine now.
good luck
Posted on Nov 14, 2007
SOURCE: GE 5.8 GHz Model No: 25825GE3-A
Posted on Feb 17, 2008
  • 6 Answers
SOURCE: registering handset
If all else fails, read the instructions.
"4. Place the handset in the base cradle. The charge/in use indicator turns on, verifying the battery is charging. The unit will take 20 seconds to register and verify its security code. READY shows in the handset’s display."
Posted on Jan 13, 2009
  • 28 Answers
SOURCE: register handset GE DECT 6.0 27918 (Lost Manual) Online Manual
Posted on Apr 12, 2009
0 characters
1 Points
Setting up my outgoing message: just purchased Uniden cordless DECT 1580. Manual says select command 8. How do I find Command 8? thanks, joan
please follow the instruction to register the handset to base
To register a DCX150 accessory handset:
1. Charge the handset completely.
2.Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
3.When the handset has registered to the base, the LCD will display Registration complete then show the handset ID number.
If the display shows Registration failed, repeat the process again.
To register a DCX200 or DCX300 accessory handset:
1.Charge the handset completely.
2.Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding find until the charge LED starts to blink.
3.On the handset, press and hold # until the handset beeps and displays Handset Registering.
4.When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
Jul 21, 2010 | Uniden Cordless Phone
I have a GE cordless handset Model 27911 that I cannot get to register to the main base unit which is a GE Model 27909. I have tried followed the instructions and still the handsets says "Not register."...
trun off phone and remove battery
remove power from the base unit
and leave them unpluged for 5 mins or more
then turn both units on
and replce onto base unit . Good luck
May 04, 2009 | Uniden Cordless Phone
Not registered
hello there i think this is because you need to register the second handset with the base here are the instructions
Registration links the base to a cordless handset. Once a handset is
registered it can use the base’s phone connection. A cordless handset will
not operate until it is registered to the base. During the registration
process, keep the handset near the base.
1. Press the flash/program button on the base until LINK HANDSET shows
in the display. 2NO is the default setting.
2. Press the 1 number key or press the MESSAGES/CID (or) button
on the base to scroll to 1YES.
3. Press flash/program to confirm handset is linked to the base. WAITING
HANDSET REGISTRATION shows in the display.
4. Press the flash/program button on the handset until LINK BASE? shows
5. Press 1 on the handset keypad or cid/vol (or) button on the
handset to scroll to 1YES.confirmation tone when the handset is successfully linked to the base.
6. Press flash/program on the handset again to confirm. You will hear a long
please leave rating if you find this usefull hope this helps thanx for using fixya!!
Jan 26, 2009 | GE 27958GE1 Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Did you follow step by step instructions leading up to Registration; i.e HS Setup and BS Setup??
Dec 28, 2008 | Jwin G.E. Thompson: GE-29257GE1 Corded...
Can't register the handset
I have the GE 28811 series and to register mine you have to unregister it first then go to your phone setup menu and select register and it tells you to hold the base page button for 5 seconds then hit your program button on the phone and it registers it.hope that helps.
Jul 04, 2008 | Uniden Cordless Phone
1. press the "talk" button FIRST
2. then press "program" button and follow instructions on screen
only one phone said "needs registration" but had to register all 4 phones but this worked for me
hope this helps
Sep 11, 2007 | Uniden Cordless Phone
I would assume this could have been a product that was returned to the company that you purchased it from. Follow these instructions. 1. 1. Disconnect power from the base by pulling the plug out of the back of the unit. 2. Press and hold the Page button and while holding the Page button reconnect the power. 3. Continue to hold the Page button until the charge/in use light flashes rapidly. 4. Release the Page button. 5. Press and release the page button on the base once. All handsets are de-registered and HANDSET NEEDS REGISTRATION shows in the display. Then From the Handset Setup Menu: 1. Press the caller ID-volume ( 6 or 5) button to scroll to the REGISTRATION sub-menu. 2. Press the mute/program button to enter the menu. REGISTRATION 1YES 42NO - - -shows in the display. The default setting is 2NO. 3. Use the touch-tone pad to select 1 for YES or 2 for NO. Or use the caller ID-volume ( 6 or 5) button to scroll to 1YES or 2NO. 4. If you select YES, press the mute/program button. HOLD BASE PAGE FOR 5 SECONDS, THEN PRESS HANDSET PROGRAM shows in the display. (Your handset should be held near the base during registration process.) 5. Press and hold the page button on the base unit until the charge/in use indicator flashes. Press the handset mute/program button. REGISTERING shows in the display. HANDSET X REGISTERED shows in the handset display, where X is the handset number. You may now rename your handset. (Refer to Step 3 & 4 of Handset Name Section) NOTE: IF you are re-registering the handset through the handset menu; to rename your handset you must go to the Handset Name Section and start from the beginning step. I understand that you have tried the registation process. Sometimes with electronics, you have to start from ground 0, before it will work correct again. If there are further questions or comments, please post here. Please rate this solutn through fix-it. Thank you
Jun 22, 2007 | GE 28111 Cordless Phone
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
Uniden Cordless Phone Logo
56 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
