Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
My Jenn-Air SVE47100 slide in electric range does
My Jenn-Air SVE47100 slide in electric range oven does not go past 100 when baking. There are not error codes but there is a high pitched beep and low pitch beep that seems to stop the warming process.
Repairman came and the oven worked fine. $75 duckos. He said to buy a new one.......I would like to fix this one. anyone know what I should do?
    President:
  • 1,723 Answers
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 24, 2009
  • Payet Dec 01, 2010
    Hey I'm having the same issue. Before paying a repairman thought I'd see if there was a known issue. No replies since first posted. Was this resolved. Was it the thermo. I'm running a cleaning cycle to see if it fixes. Every thing seems to work it just can't get the temperature right.
Bake element burned out on my Jenn-Air SVE47100 Slide-In Electric Kitchen .I replaced it but oven does not heat ,when i turn oven on and check each terminal of bake element (and broil element)from ground i...
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 26, 2011 | Jenn-Air SVE47100 Slide-In Electric...
When I press the bake button it doesn't turn on the oven and the temperature display has faded out and is no longer visible.
Most likely your control module/board has failed. You cold be looking at a relay board, which is usually on the back side of the oven, and a control module. cold be a 400-500 dollar repair. still cheaper than a new range.
Mar 21, 2011 | Jenn-Air SVE47100 Slide-In Electric...
My oven doesn't bake properly. Everything takes extra long to cook and even when I give it extra time the food usually isn't baked all the way through.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 11, 2010 | Jenn-Air SVE47100 Slide-In Electric...
We set self clean mode at 9am and its now 730pm and oven is off and cool but door wont unlock and fan wont shuttoff
I had set the oven to clean and my husband came into the kitchen and thought is was on bake and turned it off. I tired to put it on clean again and it would not clean. He tried to set it on bake and the door won't close or the oven heat. How do we reset all of this. Thanks,
Feb 08, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Oven Won't Heat
are you still getting power to the oven? breaker ok? there may also be a fusible link somewhere on the circuit
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I HAVE A JENN-AIR SVE 47100 IT STARTED TO PRE-HEAT AND STOPPED AT 140 DEGREES NOW IT WONT GO OVER 100 DEGREES BROIL OR BAKE ELEMENTS NEITHER IS GETTING HOT CHECKED HI LIMIT IT'S OK NO TROUBLE CODES JUST NO...
Probably relay control. I have similar problem.
Best estimate I have had is $300, relay control circuit board, Part #12001689 costs $225.
I am getting a NON Jenn Air. Repair record not so good.
Check Consumer Reports
Feb 26, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Aire locked tight!
Try turning the oven tempurature all the way to the right (past clean). That is what unlocks mine.
Jan 12, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Bake oven element blew
Could be the oven selector switch or the thermostat that failed form thhe element shorting out. You will have to have a ohm meter to check these
Dec 15, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
317 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
