Question about Euro-Pro Sewing Machines
Dressmaker 2 Date 2608 thread snarled on underside of material. Sewing on one layer of cotten.
  • Anonymous Mar 26, 2014
    Thread
  • 268 Answers
Here are a couple of things to try.
- Re-thread your machine, it may be threaded incorrectly.
- Raise your feed dogs if your machine has this feature.
Note:
when you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Posted on Sep 24, 2009
How do I thread my dressmaker 5700 model #18679 sewing machine?
Difficult finding info for your particular model, but this may be helpful:
Dressmaker 7000 Sewing Machine Threading Diagram
FWIW, sewing machines tend to thread very similar to other models.
Oct 15, 2017 | Sewing Machines
Fy5318 breaking thread on multiple layers of material, how to adjust?
either the thread is old, or the tension is to tight.
or there is a bind some where in the line layout.
you mite goto there website and look under FAQ section for other help
or
www.youtube.com/sewing/canvas/material/
www.youtube.com/fy5318/multiple/layers/of/material/setup/
www.ask.com/sewing/multiple/layers/of/material/and/setups/
Sep 17, 2015 | Yamata Fy5318 Mechanical Sewing Machine
Why does my bobbin thread end up a snarl on the underside of my cloth and my machine stop running.
Try changing your stitch length, if its too shortl it will bunch up under the unit.
Feb 21, 2015 | Kenmore Sewing Machines
Thread nesting on the bottom
Rethread the top of the machine with the presser foot up; sew with the presser foot down. If the fabric is too thick/too many plies, the presser foot is forced upwards, allowing the top tension to open. This causes thread snarls on the underside. See also: http://www.picturetrail.com/sfx/album/view/22521551
Jan 12, 2014 | Brother PE770 Computerized Sewing Machine
Singer sewing machine pulls fabric and snarls
try changing the needle--make sure the needle is the right one for the
fabric being sewed.
rethread the machine using every thread guide
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint
you may also have to use a washable stabilizer with the fabric
Apr 15, 2013 | Singer Sewing Machines
My Pfaff Classic Style Quilt 2027 is getting large thread snarls on the underside of the fabric.
Top tension problems. Tighten the tension.. and make sure you hold the threads when starting a seam.
Sep 02, 2012 | PfaFF Sewing Machines
I have been trying to make a buttonhole but the top thread keeps breaking and the threads are all snarled up underneath the material. what am i doing wrong? i have a brother ls2125 machine maria
Firstly have you interfaced the material that you are buttonholing on? You will never get a good buttonhole otherwise. Also start each new project with a new needle matching the size to the weight of fabric. Good guide available here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/
Top thread breaking is usually because the tension is too tight or the thread is catching somewhere in the thread path from the spool to the needle. Also check that the needle doesn't have a burr on it somewhere, or is blunt.
Thread snarls underneath the fabric is usually caused by top thread tension issues. You will need to rethread top and bottom and CHECK that the thread is in tension correctly. So lower the pressure foot and pull the top thread just before the needle - does it feel hard to pull? If not, then the thread is not in tension. Rethread top again, checking the tension dial is set to 5 and the thread is correctly pulled between the tension discs. And always hold the two thread tails at the back of the sewing area as you start each new seam to avoid these being pulled down into the bobbin area and getting jammed up.
So, rethread, test sew and get the top tension sorted, a nice straight stitch happening, then try the buttonholing sequence again.
Apr 26, 2011 | Brother LS-2125 Mechanical Sewing Machine
My bottom thread is loose and bunchy. When I checked my seam, it got progressively worse from start to finish. This is a new machine, and I'm baffled. Nothing has changed from project #1 to this project #2...
The case that holds the bobbin in the bottom has a small screw that needs to be tightened. Do so by a quarter turn at a time and test the sewing on a scrap of the same material you are working on until you get an even tightness between top and bottom threads.
Mar 13, 2009 | PfaFF Creative 7570
Sewing Machines Logo
202 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
