Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
My LCD display for sony handycam displays inverted image how can ifix it?
  • 125 Answers
The flex wire that connecting LCD to the camcorder is responsable. I bought it in the repair shop and did it by miself. save some money.
Good luck
Meggita
Posted on Sep 25, 2009
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
When on the camera the image in display is invert
This is a common problem with the flip out display feature. Either the little image inverter switch is bad on the flip out screen unit or the flex cable unit going to the display is bad. Sometimes that switch can be cleaned ,but if it's the cable it will need replacement. This problem is a display issue however ,so if you can rotate the display in another postion to where you can use the camera you can still use it. It will not effect the recording made. I fix these all the time . Repairs run from $40 to approx $165. Larry's Electronics 916-362-8708 ledstiles@hotmail.com
Apr 23, 2010 | Sony Handycam DCR-SR40 Camcorder
Sony vaio vgn nr160e laptop - no display (intermittent). Attached monitor shows display fine and laptop works fine. Screen used to flicker intermittently (last few days).
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Oct 20, 2009 | Sony VAIO VGN-NR160ET Notebook
LCD DISPLAY SCROLLS Sony Handycam DCR-SR62
Had the same.after stopped showing anything and the rest was working perfectly. Changed the flex wire connecting camcorder and it's like new. got from the repair shop and did it by miself. Good luck
Meggita
Aug 04, 2009 | Sony Handycam DCR-HC40 Mini DV Digital...
No image display on lcd screen
When i turn swicth onto Cammera, LCD screen and view finder is black ,some smears.Some time see a pictuer.
Any esle is Working good.
Mar 22, 2009 | Sony Handycam DCR-TRV33 Mini DV Digital...
No picture displayed on lcd (blank)
Does your camera playback old recordings fine? and just can't show live view to record?
If yes, then camera has problem of bad ccd imager and this part will be replaced.
Sony announced free of cost repair scheme for subject problem. DCR-HC20E is PAL system camera so Sony Support UK can be visited for free of cost repair details as your camera model is listed there.
If you live in different country, let me know to guide you further.
Thank you.
Oct 26, 2008 | Sony DCR-HC20E Mini DV Digital Camcorder
LCD Problem
I have seen backlight problems on the external LCD display. Take a flashlight and shine it on the external display to see if you have a picture. If you can see a faint picture, most likely either the backlight or backlight inverter has failed. Those LCD modules can be tricky to service because of the size. I would recommend a qualified tech for the job
Oct 18, 2008 | Sony Handycam DCR-TRV720 Digital Camcorder
Hello
If the display is defective we can supply it from Sony.
Check whether you can play the recorded images by connecting it to a PC.
Jul 05, 2008 | Sony Handycam CCD-TRV12 Camcorder
Gray LCD Screen
http://www.sony.ca/sonyca/view/english/warranty/productalert2.shtml
When the product is used in camera mode, the liquid crystal display (LCD) panel and/or electronic viewfinder displays either a distorted image or no image at all.
Sony Corporation has determined that this condition occurs very rarely, but may be accelerated if an affected product is exposed to high temperature and/or high humidity environments.
In an effort to ensure customer satisfaction, Sony of Canada Ltd. has elected to offer, effective October 3, 2005, free out-of-warranty repair to owners of affected Sony digital camera, camcorder and PDA products that exhibit the aforementioned condition caused by the image sensor device. See below for a list of affected models:
Oct 11, 2007 | Sony Handycam DCR-TRV250E Digital...
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
148 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
