Question about Refrigerators
Replace Evaporator in mini fridge
Dummy that I am . . . I accidentally punctured the evaporator in my mini fridge (it is the shelf that makes up the bottom of the freezer). When I punctured it, some type of gas (freon?) rushed out. I have access to another fridge, so I may be able to take the evaporator off that one. Any idea how easy it is to swap out this part . . .and do I need to have the system recharged after this.
  • Refrigerators Master
  • 5,568 Answers
The system will definitely have to be recharged; the escaped gas was under pressure and you cannot remove the evaporator without losing its charge.
Since labor costs are not cheap, you might consider looking at craigslist for your area and buy a used one. Even new, they are mostly around $100 US which might be $30 higher than your planned evaporator swap.
Posted on Sep 24, 2009
  • 1,606 Answers
The best thing to do , is to replace the mini fridge . Due to repair expense of evaporator , evacuation , recharging , refrigerant , sealing up the sealed system . Mini fridge barely costs over $ 100 .
Posted on Sep 25, 2009
IF REFRIGERATOR EVAPORATOR WILL BE PUNCTURED BY ANY REASON SO WHAT SHOULD I HAVE TO DO? MAGIC DEPOXY CAN STOP THE PRESSURE OF REFRIGERANT OR GAS WELDING WILL BE BEST WAY?
all refrigerant mechanics will tell you that a punctured evaporator is the death of the fridge
the metal is too thin to weld and any glue used will blow off under the pressure of the gas
basically the cost to effect a maybe repair is more than another fridge.
Aug 08, 2015 | Refrigerators
Where do I locate the evaporator on my fridge
Hi, what kind of refrigerator is it? The evaporator is generally on the back wall of the freezer, it usually has cover over it with some vent holes.
Dec 04, 2014 | Refrigerators
How could i fix my ref i was able to puncture it? .. how could i fix it?
you cannot fix a punctured evaporator coil. The cost is not economical and the repair is unreliable. best consider another fridge.
Jun 20, 2014 | Kelvinator 12 cu. ft. / 340 liter Chest...
I have an igloo mini fridge freezer model number FR320 and the freezer and fridge are in the same area but theres a metal dish or tray for the freezer part that slides into the top area of the fridge and...
You need a new evaporator. If you have not done refrigeration work before, throw it away and get a new one. Don't ever chip away at the evaporator ever again with a sharp object. an evap replacement is one of the most difficult jobs to do on a fridge. its also very costly.
Aug 05, 2013 | Refrigerators
Doesnt make enough ice and this morning we find out that it was not cold enough.
Did somebody adjust the temp control? Set the temp control properly and observe if cold is enough.
Check it, did somebody use a sharp object into the evaporator when getting something? If there's a dent on the evaporator, chances are a small hole punctured will cause freon to evaporate. Hence a leak in the system is already there.
I hope I give you idea regarding your fridge problem develop.
Jun 24, 2011 | Samsung RS2630SH Side by Side Refrigerator
The freezer in my mini fridge started making a hissing sound today something stabbed the bottom of it whats going on is it safe to use ?
From what you are saying the evaporator got punctured. The hissing was the freon coming out of the unit. The unit will not cool even if it was plugged in.
Apr 22, 2011 | Refrigerators
Punctured evaporator on my Sanyo SR-2570 fixable?
Unless you know someone that can replace the evaporator and regas this unit very cheap as it's a major job, I'd say it's alot cheaper to buy a new one. cheers
Oct 30, 2009 | Sanyo SR-2570 2.5CF Mid-Size Dorm...
I HAVE A HOLE IN THE REFRIG.LINE OF A HAIER MO.HC125FVS
Hi, unfortunate, sorry to hear that, but it could be repaired, you should immediately dried up water/ice around punctured area, prevent water/ moisture entering punctured area (evaporator. lines), it's one of the worst thing, that could happened to any refrigeration system, it will be costly to repaired, if water get into your evaporator lines, compressor oil have to be replaced, evaporator will need to be flush out, repair puncture, change filter drier, it's better to replace compressor, vacuum system for about 2hrs. then recharge. it's better to use welding/ soldering, to repair punctured line, epoxy repair kit can be used to repair punctured (evaporator) lines . you will have to call a mechanic, if very little water entered punctured( evaporator) lines, then flushing of evaporator, (internal cleaning of lines (tube) changing of filter drier, with overnight vacuuming will do the job. take note, job like this, cannot be guaranteed. check cost for repairs, sometimes it's better to purchase a new one, and save yourself some headaches.next time never use sharp instruments in your freezer, it happened to me sometimes, it's what you get your hands on, what's available at the moment, good luck.
Aug 15, 2009 | Haier HC125FVS Wine Cooler Beverage Cooler
Re: Sanyo SR4310W mini fridge freezer plate broken
Ok, I know I should not have done this but I did. I was impatient with the defrosting and stabbed my Sanyo SR3770s' evaporator with my Smith and Wesson switch blade knife. A very tiny hole, made a swooshing noise and now the fridge won't get cold. Can this be repaired for a minimal price? Perhaps just replacing the evaporator plate and reinstalling some freon, maybe, hopefully?
Let me know. Basically a brand new unit, hate to see it go to the dump!
Sandra
Jul 20, 2009 | Sanyo SR-4310 Compact Refrigerator
Punctured a hole in the freezer compartment
That type of damage is usually fatal to the unit. It is difficult if not impossible to repair in most cases depending on the metal used to make the evaporator, and what kind if equipment the repairman has. You can't fix this yourself, consult a local repairman, explain what happened, and the model of the unit, and ask if repairable what it might cost. Or just buy a new one. And NEVER use sharp objects in an effort to remove frost buildup. Turn it off, put your stuff in a cooler, and use a heat source such as a bucket of hot water in the unit with the door closed
Jul 18, 2009 | Haier ESR042PWW 4.2 Cubic Foot...
Refrigerators Logo
1,285 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
