-   I also have a GE Nautilus Part # GSD2200G02WW I turn it to start and it will fill and I here the jets washing but it just sticks at start and water never drains. Any advice -   scottlaj
Jun 28, 2008
-   my machine washes but wont drain anyone know what i can do?-   donnabednall
I just fixed this problem. Cause, a bone in the drain pump fins. Soloution: Get as much water out of the unit as possible, get a bunch of towels.Turn off water and dicconect all lines including the electrical. Pull unit out from under the counter and turn on right side (GE model that I have), mop up water off floor. Find the drain line and disconect from pump. Get your Torx set out and remove the 3 screws holding the housing and gently lift the pump motor. Remove the clog/blockage and replace the motor being CAREFUL to get it in straight so that youy don't screw up the big O ring. Replace all the screws etc. Hook up all the lines as you re-insert the unit back under the counter. This woked for me but as you can tell I had no "broken" parts.
I have an older Blanco bfdwc60 which has just started tripping out fuses part way through the cycle....
(More)
I have an older Blanco bfdwc60 which has just started tripping out fuses part way through the cycle. Any ideas?
Dishwasher will not fill with water, just bought it second hand, 3 programmes set using rotary knob,...
(More)
Dishwasher will not fill with water, just bought it second hand, 3 programmes set using rotary knob, then push button to start, seem to work, it has stood for over 1 year without use. Entry pipe filters look clean, no water enters, cannot hear a valve open.
Hi, I have a LG dishwasher - LD-2040WH. I think the springs in the door have broken or become loose...
(More)
Hi, I have a LG dishwasher - LD-2040WH. I think the springs in the door have broken or become loose as the door crashes down to the floor unless you guide it down with you hand. Can I fix this? Thank you
