Question about Maytag Neptune MDG5500AW Gas Dryer
Dryers turns on pilot only lites for a minute and turns rite off
    President:
  • Maytag Master
  • 1,922 Answers
Either your flame sensor is bad or the entire control unit is defective
Posted on Sep 26, 2009
Put in new ignator will not lite
Did you follow installation instructions on the ignitor? The pilot light may have gone out. Try turning the gas off to the dryer for a couple minutes and then following the pilot light lighting instructions for the valve assembly. Youtube has many good videos on this as well.
Dec 01, 2014 | Maytag Dryers
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Need to relight pilot light on MDG6200AWW gas dryer.
That unit has an electronic ignitor. You should not have to lite the pilot. There is no pilot to lite. If the dryer is taking longer then normal to heat. Check your vent to the outside. If the ignitor is not turning on it could be the ignitor, flame sensor and or thermal fuse. Check D.I.Y. Appliance Repair Troubleshooting to see if there is anything that can help you there.
Mar 28, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
I think my pilot light went out, but I need to know how to locate it
Dryers do NOT use a standing pilot lite ..When the unit is turned on and heat is commanded on the gas valve opens and an igniter lite's the gas , then their is a flame sensor to see the flame from the burning gas if no flame is present it shuts the gas back off.. So if you have a no heat concern with your dryer it will be either the igniter, gas coil's or the flame sensor
Jan 03, 2011 | Dryers
I want to light the pilot but do not know how what is the red button for and do you turn on the gas to light pilot?
nope - don't turn on gas at the Range's front control panel to light the pilot lite.
but you do need to turn on the gas to the kitchen range at the plumbers black pipe valve to the Range.
To light the pilot light:
(1) depress the red button (that feeds the gas to the pilot light orifice)
(2) using lighter/match/lit rolled-up newspaper, etc, light the tiny amount of gas coming from orifice
(3) continue to hold dow red button for 1 or 1.5 minutes (this allows heat to bend the bi-metal contact)
(4) after 1-1.5 minutes with a lit pilot light, release the red button - the pilot should remain lit
(5) you're done lighting the pilot lite - turn on the oven (or broiler).
Dec 27, 2010 | Kitchen Ranges
Pilot lite won't light
I believe your heater uses a" Glow plug" style igniter not a traditional pilot.This type takes a few minutes to lite. Be sure the correct pump is running,the gas valve is turned on, and the Bypass valve is at least 1/2 way closed.Also make sure you have at least 10 psi on the filter gauge.
Oct 08, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Want to relight pilot
Turn off gas valve to OFF, let the fumes clear out for 10 minutes, THen press turn, and hold in PILOT position, Light the flame (you will see the little nozzle where pilot is) Keep holding for 1 full minute, then turn to ON position and let go and that's it. Your good
Jan 22, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Jandy Lite 2 - Pilot goes out when I turn to On
Sounds like you need a new thermo couple. found at most hardware stores
Jun 23, 2009 | Jandy Lite2 LG400 Ceramic Compact Heater
Gas wall heater won't light
You need to bled the line longer and when you get lited hold down for a good minute.When the gas gave out ,there could trash in the line.I would take the line off and blow gas through it undtil you can smell it.
Mar 12, 2009 | Heating & Cooling
Laars lite 2
you will need to take pilot assembly out and replace thermal couple also check flue
May 04, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Maytag Neptune MDG5500AW Gas Dryer Logo
96 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
