Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Mixer will not run - KitchenAid KSM150PS Artisan Series Stand Mixer
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 143 Answers
There are a few things that could cause your mixer not to run. If the carbon brushes located on the left and right side of your unit are worm are gone your mixer will not operate. part number for both brushes are 9706416.Take good notice on HOW these come out as they will only work ONE WAY. another cause of this could be from simply a burned wire often this will be the case. if after checking the wiring visually by taking the back off. another possible cause of this could be from a bad field winding or motor.
Posted on Oct 11, 2009
The mixer runs but the beater doesn't turn. Drive shaft?
a gear or gears. their usually plastic and will damage before the drive shaft
Feb 07, 2013 | KitchenAid K45SS Classic Stand Mixer
Mixer only runs at one speed
if it runs only at high speed it needs a new phase control board if the mixer is post 1978, if the mixer is pre 1978 then you will have to replace a capacitor on the end of the power cord inside the mixer. if the mixer only works on one speed that is not high speed then you need to adjust or replace the speed control plate on post 1978 mixers and the capacitor on pre 1978 machines. Hope that helps
Jan 30, 2013 | KitchenAid Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
Kitchenaid stand mixer runs only on slow speed
The Kiichenaid mixer has a centrifugal speed governor. I suspect your is stuck. It will need to be disassembled, and inspected.
Jun 28, 2012 | KitchenAid Food Mixers
Mixer runs backwords
if your mixer is a 3 phase, you can change any 2 legs feeding the contactor, after switching any 2 legs , looking from the front of the mixer rotation should be ccw
Jan 29, 2010 | Food Mixers
Kitchenaid mixer running too fast.
Change the speed control board. Repair alot of these
Dec 24, 2009 | KitchenAid K45SS Classic Stand Mixer
Seemingly well maintained H600 mixer only runs in reverse...
whoever wired the mixer in , hopefully 3-phase made a mistake on the incoming pwr to term block or the contactor switch any 2 leads this should reverse rotation of the mixer
Nov 04, 2009 | Hobart H600 Stand Mixer
KitchenAid 2671 onmly run Stir and Second at high speed
Hi. Goto kitchenaid.com and download the parts catalog for your mixer model, these drawings will assist you in the disassembly and reassembly of your mixer.
You'll need to replace the speed control in your mixer. This is a common problem. Be prepared to wait at least a month for your parts to arrive. Unplug your mixer before you open it up.
If you're still under warranty call kitchenaid!
If this solution has assisted you, please rate it. Good luck! ricardok45
Jan 28, 2009 | KitchenAid KP26M1X Stand Mixer
Sometimes mixer runs when turned on, sometimes not
Sound electrical to me.... what kind of mixer ?
May 27, 2008 | Food Mixers
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
178 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
