Question about Foxconn 45CMX socket LGA775 motherboard (16897)
Steady beep code
Its just one steady beep code
    Problem Solver:
  • 6 Answers
If you're using an add-on video card, check it to make sure it's functioning. make sure the video is seated properly, if it's an add-on card. if the video you're using is onboard, try an add-on video card. also check your memory. make sure it's (they're) seated properly. careful of ESD. disconnect power from computer when doing all this. reconnect power to check if what you did worked, (naturally).
Posted on Sep 24, 2009
Why does my emachine w3644 desktop keep beeping when i turn it on
Does it beep steady or beep so many times and pause and start all over?
Jul 05, 2014 | E-Machines eMachines Desktop PC
New gateway dx4840 lga1156 core i3 and I get a steady beep sound. not a beep code. even with everything disconnected
I had that happen before when my RAM went bad. I think I shorted it out by not having it clicked in all the way, I don't remember. Maybe try swapping some RAM out one at a time and see what happens. Make sure the RAM is also in its right spots (like if you have 4 slots there is one in slot 1 and not in slot 3) I hope this helps.
Feb 04, 2014 | Foxconn 45CMX socket LGA775 motherboard...
Mercury outboard motor
different beeps for different things. . .fast broken beeps over heated long steady beep water in gas long steady beep then broken beep low oil this is something you need to take to shop with don't risk trying to poor boy it
Sep 23, 2013 | Boating
Having installed this motherboard in the case and connected up I get a series of fast beeps a few seconds after power-up. I have immediately powered down. What is causing this problem? There is nothing in...
In your case, it is a memory problem. It's either one of your RAM has problem if you have 2 slot RAM. Please ensure that you have the right RAM for your board. You can also clean the contacts of your RAM by using eraser.
Below are the most common beep code that being adopted to most BIOS for reporting.
  • short beep - Normal POST(system is OK)
  • Steady short beeps - power supply problem
  • long continuous beep - memory failure
  • Steady long beeps - power supply problem
  • 1 long, 2 short beeps - video card problem
Apr 06, 2011 | Gigabyte GA-G41M-Combo Motherboard
All i get is a beeping My gt5220 will not boot...help
Does there seem to be a pattern to the beeps? (long beep, pause, long beep or 3 beeps and a pause) The codes will depend on the motherboard and BIOS manufacturer. One of the Gateway code lists: http://support.gateway.com/s/MOTHERBD/Intel2/WMEBLKD925XBCLK/WMEBLKD925XBCLKfaq17.shtml .
One beep is a CPU error. Three beeps is a memory error - you can remove and reseat the memory one stick at a time to find a bad stick causing them all to fail. Eight beeps is a video error.
I hope this helps.
Aug 29, 2010 | Gateway GT5220 PC Desktop
Dell optiplex sx270: loud, steady noise like an alarm a few seconds after I turn on the PC
You can check the meanings of the error beep codes HERE. Every beep code means something different. The bad thing is that the code I think you are speaking of is a fatal error.
Good luck
Aug 26, 2010 | Dell Computer Refurbished OPTIPLEX SX270...
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
Constant buzz after beep...
Hello
These are sound codes or beep codes.Usually one long steady beep is a problem with your memory or cpu is not onstalled correctly
Apr 21, 2010 | Gigabyte GA-EP45-UD3R Motherboard
Won't boot, has a steady beep sound.
Beep codes denote that there may be problem with your RAM modules inside your computer Cabinet. Remove the cabinet, remove the RAM modules from the slot, clean the dust particles present and replace the RAM back to the slot properly and try restarting your system. Try 5 continuous attempts like this and at any one your system may come alive. The Beep codes may vary among different motherboard vendors. So refer to your system motherboard manual and there the interpretation for different kinds of beep code will be provided.
I hope this is helpful and solves your problem,
Thanks
Feb 20, 2010 | HP Pavilion m7480n (882780389410) PC...
Foxconn 45CMX socket LGA775 motherboard (16897) Logo
258 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
