Question about Gigabyte GA-7VA Motherboard
Unfortunately i pulled out the panel switches from the motherboard. How should i connect them back. namely the power, reset, hdd led etc
    Scholar:
  • 138 Answers
Go to this site and download the manual. then go to page 23.
Posted on Sep 24, 2009
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
Where can i get pyramid-9 PCB No BA41-00167A manual book for setting up power switch,hdd led,reset etc connection setting ???????????
Hello, i was made a search in google, i guess you must look it too, and a don't get nothing, but, I think i've a solution for you, according my own experience, i've installed 2 kinds of different MB, and, althoug there are different brands, the connection pins are the same, ie, the front panel connector that connect HDD Led, Power Led, Reset and Power, is a 9 pin conectors (really have 10, but 1 pin is cut for reference) and commonly is called PANEL 1
Then, i guide you
2 8
. . . . this will be 2,4,6 and 8 pins (from left to right)
. . . . . this will be 1,3,5,7 and 9 pins
1 9
Power Led + in pin 2
Power Led - in pin 4
Power Button # or + in pin 6 (It's no critic the orientation, it have no polarity, is a push buttom)
Power Button GND or - in pin 8
HDD Led + in pin 1
HDD Led - in pin 3
GND from Reset Buttom in pin 5
# from Reset Buttom in pin 7
THE PIN 9 has no connection
Source: My own experience, and check this instalation manual, at 21st Page
http://download.asrock.com/manual/Wolfdale1333-D667%20R2.0.pdf
Jan 07, 2011 | EPoX EP-3PTA Motherboard
I need to connect the(power led,reset switch,hdd led,dc switch)
Well I was a little confused since your category is with the Gigabyte.. k.. let's proceed like this.. First of all refer to this Photo.. eb607bc.jpg See the Arrows direction, when you carefully look at the male connectors (pins), you'll notice that there's something written beside them.. P or power or pw switch Reset switch, hdd led, power led etc.. Here you have to connect the corresponding connectors in the direction (This Way) shown with the arrow, as of now.. Vertical direction not horizontal, or else there might be problem later.. so check this carefully and do the connection. If you still can't make out, let me know again.... Good luck.. nonontech@gmail.com
Apr 29, 2010 | Intel Motherboard
I just installed my motherboard samsung harappa-4 on new casing, but i don't know how to connect cable for power switch,power led,hdd led, and reset, please give me solution, thankyou very much
LOOK FOR THE FRONT PANEL PIN HEADER.
IT MUST BE SOMEWHERE BY THE EDGE OF THE MB.
THERE ARE MARKINGS LIKE HDD LED, PWR SW ETC.
HOPE THIS HELPS.
Apr 13, 2010 | Computers & Internet
Front panel motherboard samsung harappa-30 PBA:BA59-00905A
i wont to sound drivers for polaris motherbrod
Jun 12, 2009 | Computers & Internet
Front panel connectors
Pin Signal In/Out Description Pin Signal In/Out Description 1 HD_PWR Out Hard disk LED pull-up (330 ohm) to +5 V 2 HDR_BLNK_GRN Out Front panel green LED 3 HAD# Out Hard disk active LED 4 HDR_BLNK_YEL Out Front panel yellow LED 5 Gound Ground 6 FPBUT_IN In Power switch 7 FP_RESET# In Reset switch 8 Ground Ground 9 +5 V Out Reserved 10 N/C 11 Reserved In Reserved 12 Ground Ground 13 Ground Ground 14 (pin removed) Not connected 15 Reserved Out Reserved 16 +5 V Out Power
Hope this helps, , if so please rate accordingly.
Thanks,
David
Mar 12, 2009 | Intel Motherboard
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Connection
pixel.gif pixel.gif =1024) && (screen.height>=768)) { document.write( 'pixel.gifSearch
btips.gif'); } //--> dot.gif
dot.gif manual, information? Part number
Manual
Warranty information
Refund information
Rebate information
Serial numbers / manufacturer numbers
Billing information
Missing or lost CD, disk, or install file
Upgrade information
Part Number There are literally millions if not billions of different part numbers used by companies today. Because of the vast quantity of part numbers and the frequency of those numbers getting changed or referenced to other numbers, Computer Hope is unable to offer its customers with third-party part numbers.
If you are looking for a part number we recommend that you contact the computer company or the company responsible for supporting your product. You can find a listing of companies and their contact information on our company listing.
If the company responsible for your product is no longer in business we recommend the below.
  • If you do not have any numbers, but have the product or part you wish to replace, ensure that no numbers are listed on that part. If a number or name of company is listed on the product see the next section. However, if no number can be located we recommend you take the product to a local service center, repair shop, or the place of purchase for additional assistance.
  • If you are able to locate a number, attempt to search the Internet with a large search engine for that number. If you are unable to locate that number we recommend you take the product to a local service center, repair shop, or the place of purchase for additional assistance.
  • If you are only able to locate the name of the company who made the product, attempt to contact that company directly to see if they can provide you with a replacement. See our company listing for contact information.
Also see: Part Number (PN) Computer Hope dictionary definition.
Manual suggest you visit the manufacturer of your product web page.
Also see: Manual Computer Hope dictionary definition
Serial Numbers Unfortunately, with the billions of different serial numbers and manufacturer numbers, contact the manufacturer of the product or look for information about the product on Computer Hope by searching by the manufacturer or type of device name. For example, instead of searching for "Serial Number 12345" it may be easier to search for "Maxtor hard drive".
If you are looking for a serial number for a particular software program you will need to contact the software developer or producer of the software program; Computer Hope will not provide any type of serial numbers or other registration numbers to any users. See our underground section for additional information to why Computer Hope does not provide this information.
Finally, a serial number for a hardware device such as a computer or printer can almost always be found on the bottom or back of the device. If you're trying to find the serial number for one of these devices try physically examining the device. If you're still having issues locating it the contact the manufacturer .
Missing or lost CD, disk, or install file If you've lost one or more of your installation CD's or diskettes you must contact the developer of that program to obtain a new copy. Computer Hope cannot send anyone copies of the disks or downloadable files over the Internet of the program regardless if you have purchased the program.
Dec 06, 2007 | Computers & Internet
Gigabyte GA-7VA Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
