Question about Eljer Toilet Onepiece Canterbury 081162047
My Eljer toilet is clogged and a plunger doesn't fit over the hole. What do I do?
  • 129 Answers
You will need to buy a closet auger (lowes or home depot)
Posted on Sep 26, 2009
Flush's to the front only
Just make sure the back is not clogged.
Jun 24, 2013 | Eljer Home
Where do I find a part number on an Eljer toilet tank?
You can purchass a whole new fixture for the same cost as just the tank I believe...
any eljer tank will fit your toilet bowl... they are pretty universal.
Does the current tank have a crack or something?you can replace the seals easilly enough if the tank is just leaking at the seal ... and the flush mechanism is also easy to replace , should that be the reson to swap out tanks too.
Mar 24, 2013 | Eljer 141-0220-00 Toilet Tank White
Water over flowing from the toilet
It must be clogged. Try using a plunger first. If thayt doesn't work, consider using a "toilet snake". Simply place the end of the flexible cable into the toilet bowl and begin unwinding. The cable will extend round the bends in your trap way dislodging any clogs as it goes. If you come to the point where you feel some resistance, you will need to rewind the cable back into the bowl and remove anything that comes up with it. Repeat this process until your toilet runs clear.
May 18, 2011 | Home
Toilet does not completly flush. It stars out right, then kind of just fissles. acts like its sucking air, or loosing suction.
Hello
Could be a clog blocking the vent.If the vent is blocked then you will get this kind of problem.
Best thing to do is get a plunger and unclog it.Also check that the water supply is full and the tank is full.
Mar 14, 2011 | Eljer & Complete Toilet In A Box
Toilet is leaking between tank and seat. the water that is collecting on the back of the toilet is blue. what does that mean.
Check for any loose connections or a crack in the pump casing. Check all the rubber fittings also for any holes or cracks.
Oct 11, 2010 | Eljer TITAN 15" Two-Piece Toilet -...
Eljer toilet
Hello there:
i would either get a snake and have the lines snaked out or get a good quality plunger and use that if you can get it to go down i recommend before you flush it get a small trashcan and fill it with steaming hot water and pour it down the drain and if needed do it 2 or 3 times this will help release any greasy residue that may have gotten in the line than you would be good to go ok?
best regards michael
Sep 21, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Eljer century toilet splashes water up on toilet seat
You can try replacing the flapper with a timed flapper. You can purchase one at Home Depot and they are made by fluidmaster. Set the flapper on the shortest flush time thus reducing the flow of water. If this doesn't help, try to isolate the particular holes that are causing the greatest amount of splash. Using an epoxy glue (after the holes are completely dry) plug them up with the glue. This is a permanent fix so be careful.
Apr 10, 2009 | Eljer Toilet Twopiece Century 091820543
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
535 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
