Question about AudioSource Amp Two 2-Channel Amplifier
Audiosource amp two intermittent distortion in monoblock mode
How's it going,
I have an Audiosource amp two that I use in monoblock mode, and sometimes the amp cuts in and out with distortion, but other times it sounds great. I've checked connections to the speaker, input cable and all are OK. If I give it a good firm shake with both hands, sometimes it stops but not always. Help!
    Novelist:
  • 169 Answers
Good question, well constructed, a real fault report.
I would say from you fault description that maybe there is a dry joint / loose connection somewhere in the system.
So check all your wiring / connections.
Put the amp back into 2 ch mode and check each ch with the same source and load, do it both cold, and then drive the amp and do it hot do the shake test on both ch, cold and hot.
maybe this will help id the faulty area, if both ch have fault the it might be the psu as this is common to both sides.
If you can track down the fault to a or b then you can resolder all the connections on the board, if you are not happy with taking the lid off then take your amp with your test report to a tech, the test results may save you time and money.
Hope this helps, thanks for using FixYa.
Posted on Sep 24, 2009
Where do I start testing?
I would check if the amplifier somewhere gets hot. Most likely with a certain temp the amplifier will go into protection, Avoiding damage to the vital parts.
When you can find the place where it becomes hot, perhaps you can see if a transistor, or am integrated circuit is not correctly fastened. Before fastening it, perhaps you should apply cooling paste. (Like you use between a microprocessor and the van)
Perhaps it is only running hot, because you want to much power?
To loud.
Jul 25, 2014 | AudioSource AMP-100 2-Channel Amplifier
Audiosource amp 100 on lower volumes right speaker louder than left speaker 2.1 setup
The problem is not due to how the circuitry is configured; the problem is due to failure of some element in the right channel amplification circuit. This will require detailed troubleshooting to correct.
Dec 07, 2013 | Audio Players & Recorders
Audiosource amp will not turn on
Ground and Remote wire ? Common issues I have run into.
Mar 24, 2013 | AudioSource AMP-100 2-Channel Amplifier
How do you connect the EQ200 to the mains ? I put a 3 point plug on mine and it just makes a buzzing noise ! Can someone help me ?
you have to tell us the rest of the sytem. Typically you will use INSERT cables, but that depends on the mixer or amp arrangement.
Aug 31, 2011 | Audiosource EQ200 10Band Stereo Graphic...
I have an audiosource amp 350 watts the volume is not as loud as is should be????
How loud do you expect it to be?
More watts doesn't mean more loud but it gives you more headroom for cleaner reproduction of very loud passages. Distortion will kill a speaker faster than clean signals will.
http://en.wikipedia.org/wiki/Audio_power
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Audiosource-AMP100-Amps-manual/id/18809dj391/t/2/
I don
Mar 26, 2011 | AudioSource AMP-100 2-Channel Amplifier
Looking to hook up an audiosource EQ100 to an a sony cass deck
Simply place it in line with the analog input. Or install it in a Tape Loop on your integrated amp/receiver and attach your tape deck to ITS tape Loop.
Ins to Outs
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
Be advised, using analog processors on digital-capable multichannel elcetronics will only work for analog 2-channel sources.
Mar 05, 2011 | AudioSource EQ-100 Home Equalizer
My audiosource 2 channel amp is dead in the left channel
Hi...
There's not alot of innerds on these amps.
They use a TDA7294 amplifier chip in the 50 WPC version and I have one here with both outputs gone bad.
The chip is cheap (<$10)
Apr 01, 2009 | AudioSource Amp Two 2-Channel Amplifier
Center channel speaker
Is the amp already used for L R? If so, you either need another amp for center, or set your Sony for stereo mix down. I have mixed the center channel into my main LR in the past and found there were terrible phase cancellations, so I suggest you switch to Stereo, or use a separate amp.
Regards
Peet
Jan 13, 2008 | AudioSource Amp Four 2-Channel Amplifier
Onkyo 605 Reciever no sound from zone 2 RCAs
did the AS amp ever work properly from the RCA's?
Dec 05, 2007 | Onkyo TX-NR801 Receiver
Hooking it up!
If the amp has PreIn PreOut connections, then thats the best way to go. Home theatre amps however, have 5 InOuts, and this makes it hard. You can use the tape loop. Hook up the rec out on amp to inputs on EQ, and output of EQ to tape in an amp, then engage the tape monitor function whilst ensuring that the rec selector has the source you wish to use the EQ for.
Nov 08, 2007 | AudioSource EQ-200 Home Equalizer
AudioSource Amp Two 2-Channel Amplifier Logo
160 people viewed this question
Top AudioSource Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Are you an AudioSource Audio Player and Recorder Expert? Answer questions, earn points and help others
